The 4 bolts on the side of the hitches are adjustable to square them up.![]()
They do look a little bit at an angle. Hold a straightedge along the middle of the lower lift arms and the middle of the hook (where the lift pin goes). This should line up.
The Pat's kit should have had some spacers (shims) that you can use to square things up. At least the old sets had those chunks of metal in different thicknesses. Either call Pat's (Greenwell Mfg.) for some or make them yourself. They fit along the top of the lift arm and slide into the Pat's to make it stable. Then when you clamp down the U-bolt, things will be tight.
The four bolts / set screws on each hitch are just for keeping the hitch in place after the shims are used to make everything line up. They are not nearly strong enough to overcome a heavy implement's torque on the hitch.
Would these work on BX25d? Has anyone had experience. This would make life so much easier. Sometime talk myself into doing by hand rather then trying to hock up implement.
I dont see why they wouldnt work. You might need to buy a longer toplink.
Ah, now I understand more clearly.I do have the shims installed they do not align it the way I think its angled. Thats one of the only angles I feel is "ok".
If it was steering, id say it looks "toed in"
You're not supposed to leave the spacer bar installed while using the implement, it is only for hooking up the implement. My tractor came with telescopic stabilizers and I agree that they work excellently with the Pat's hitches.I have them on my Bx25D and love them. I originally bought the spacer bar but bent it with one of the implements. Now combined with Hodges stabilizers no need for spacer bar. I have pics in my profile.
Thanks and bought with shipping amazon same price as others more or less.
Be here Friday...
Got them on work as expected the rod is needed to line up for sure. Took a good hour to position where wanted with adjustment screws. But I have OCD with those types of things. I would buy these again
What width did you align them straight at? I had to pick a middle for my implements. My thinnest Cat1 was 25" and the widest was 32". I settled on using 28". See how it goes.
Some of the bolts loosened up with the rotary tiller today. I will have to retighten everything again. Might do as some suggested and replace them with grade8 bolts.
Yes.Some of the bolts loosened up with the rotary tiller today. I will have to retighten everything again. Might do as some suggested and replace them with grade8 bolts.
