Parting out F2400 with 72” Deck
8,716
How much is always good to add to a post.
and Why parting it out?
What's bad on it?
If it was closer and/or I could get into Canada, I would really consider it.
I really want one of these!
sfsouter
F2400
Apr 8, 2020
Spruce Grove, Alberta, Canada
These machines are held together between the rear engine section and the front transmission section by a steel frame the bolts into the transmission casting. My casting has a few of the mounting bolt holes broken off which caused the machine to flex and take out the clutch and related shafts between engine and transmission. If someone was a decent welder they could weld up reinforcements off other areas of the frame, but the correct factory fix is a new high/low speed transmission casting, the two shafts, new friction plate, release bearing, etc. The 72” deck is perfect and has a new drive shaft. I’d let it all go for $1500 usd or $2100 cad at this point.
sfsouter
F2400
Apr 8, 2020
I just checked and the engine for this tractor is a D1105ER-AG. Rebuild cost I found online is $3275 USD plus $1000 USD core charge. My engine runs like a champ!
8,716
I'm really interested in the whole unit, I'd like to see some pictures, I'm working on a way to get it down here. ;)
