Outside the Cab Hydraulics Controls Solution for Kubota MX5400 cab
GeraldVG
M7060, 8' 3008 BushHog and fairly long list of older implements
I am age and mobility compromised and looking for outside the cab hydraulics controls (3 pairs) for an MX5400 cab tractor.
I also had the cab upgraded with an air ride seat and will be adding front and rear LED work lights (to replace OEM halogens) as well as front and rear cameras on bars, all attached to the present light brackets.
Does anybody know of a source or DIY solution for outside the cab control of the rear hydraulics? :unsure:🥴👨‍🌾🚜:unsure:
kubotafreak
Sep 20, 2018
1,022
375
Arkansas, US
Can you give an example of use? Log splitter, or post driver?.. If you already had the facotry remotes, one could add exterior push pull cables fairly easy.
