Operating the Engine Heater
gssixgun
L3600, FEL, SnoBlower, Box Blade, Rear Blade, Forks, Cultivator, Plow
Jan 5, 2013
258
47
Sandpoint ID
www.gemstarcustoms.com
In this thread a couple of statements caught my attention
http://www.orangetractortalks.com/forums/showthread.php?t=9529
So I wanted to ask directly about the Engine Heater, I haven't found the answer here or in the Manual..
My Tractor sits in a Pole Barn 24/7/365 it has cover but the barn is not heated..
Reading the manual says the the engine heater should be used at -4°F and below..
My question is, Will it harm anything to leave the heater plugged in all the time ???
I normally have to hit the road at 5:00 am to make sure it is clear for the Wife to head out to work by 8am. If I don't have the heater plugged in I would have to go out at 4:00 am plug it in the go back out at 5:00 am to fire up the tractor..
I also have access to a Thermo-Cube that only switches on at 0°F and switches off at 10°F
So what do you guys think, will it hurt the Heater or the tractor to keep it plugged in ???? use the cube??? or just get up earlier and deal with it when it gets cold ???
TIA for any respones
fast*st
M7040, L2900, F550 ford, Yanmar vio70 excavator, Case 580, JD 350 dozer, JD 644E
Jun 26, 2012
172
Northern Mass
I don't think it'd harm a lick to keep it plugged in though it's going to consume someplace between 1 and 1.5 kwh so an additional 750 and 1100 kwh per month. Now if you just wanted to plug it in the days that its going to be needed thats fine. Kubota/JD/Cat fast response generator engines are plugged in and kept over 120f at all times summer and winter. It wont harm the heater or the engine, only your wallet.
Gundoctor
Kubota M7040 4x4/ BX2230 4x4/ JD MX 8/ Ford 101 Moldboard 3 bottom Plows -
Only heat it when you are going to start it and use. Get a timer that will come on when you are in bed . Then it will be ready to go when you are. That what I do here in Vermont.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
77
Rocky Face, Georgia
I used a light timer on my truck and it worked fine. Just remember to give it 2 hrs of heating time to really make it worth while. If you like the thermo-cube may look at TSC. Their's turns on at 35 degrees.
dsmiley
BX25
Dec 15, 2011
Augusta, ME
I have a BX25 with a block heater which heats the coolant and I had the same question. I posted about this in another forum and the consensus there was that you could leave it plugged in 24/7. I eventually called my dealer and was told the same thing. I now have it on a remote control so I can turn it on from over 100' away. This morning with temps in the mid teens, 2 hours on brought it up to running temperature, so it was start and go.
Sterno
Kubota B6100D, B7100HST, Ber-Vac S51 3PT Snowblower, Kubota A450
Dec 9, 2012
74
12
Summerland, British Columbia
One quick point about cold weather starts. Remember that an engine block heater doesn't heat your transmission/hydraulic oil.
This is especially important to those of you with HST transmissions, I'd still let it run and circulate fluid for 5-10 minutes in cold weather or stick a magnetic heater to the trans.
Saxman
L3830 ZD21
Jun 19, 2010
155
Mt. Vernon, IL
I have a timer on my powerstroke and set it to come on about 3 hours prior to me needing the truck in the morning. I will do the same for my 3830 prior to needing it for snow removal.
