Operating B7100 with a worn clutch
chetcromer
1981 Kubota B7100 4WD
Hi all,
I'm relatively new here because I just bought my first Kubota a couple weeks ago. The setup is great, B7100 4WD with a loader and Woods finish mower. The one issue is what we believe to be a worn out bearing on the clutch - when in neutral with the clutch disengaged (pedal pressed), it growls like a beast (not sure that's the technical term, but it seems to be a distinctive sound for clutch issues). I have a guy set up to help me split the tractor and replace the bearing (along with the pressure plate and disk while we're in there) but that's a week or two away.
It is BEAUTIFUL outside though! :) The grass is starting to grow, and I'm dying to try this thing out. Will I cause damage to anything other than the clutch parts I'll soon be repairing if I throw the thing into gear and take it for a spin around the yard (just about 2 acres to mow at this point)? The growling noise is actually diminishing a bit as I've moved the tractor around a bit over the last week, so I wonder if it accumulated some rust or something and is actually not as bad as it sounds.
So yeah... I really want to try out the mower, but don't want to do damage to the transmission or engine or anything else in the process. Shifting is working pretty clean, has driven fine as I've moved it around the barn and took for a spin around the yard in all 6 gears... but I'd appreciate your thoughts.
Thanks!
Piker
2012 Kubota 2320, 2002 Honda Rubicon
Dec 1, 2010
164
Riverview, NB, Canada
Hi all,
Thanks!
Drive 'er! Throwout bearing is under load & rotating only when the pedal is depressed to change gears. Won't hurt a thing.
chetcromer
Thanks guys! I'll double check all fluids and give it a try... make sure I'm not missing anything here:
1. engine oil.
2. transmission oil.
3. fuel
4. coolant.
any other fluids in this thing? I know there's hydraulic fluid for the loader, but it's working fine and not leaking.
Piker
Dec 1, 2010
164
By the way, I know you guys like pics... so here's my new workhorse. Pretty good shape for a 33 year old machine, don't you think?
Holy Crap! Split my 1980 B7100 last summer to replace the clutch/pressure plate/throwout bearing & painted chassis/tin while I was waiting parts - looked way worse than yours. Looks awesome now & had new decals made also.
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
333
34
Alberta
Looks real good. Its nice to see it parked inside. Time almost stands still as soon as something is under a roof. I shake my head when I see people leaving stuff sit outside year after year.
James Williams
B7100, brush hog
Oct 15, 2010
10
Dallas, Texas
The steering gear box fluid is very important on these machines as parts are very hard to come by and very expensive if you can find them. Also couldn't hurt to change fluid in all three gearboxes in front axle. I put 80-90 weight gear oil in mine. Others may have different opinions.
There is a grease zerk in the clutch system. It can be accessed through a hole on the left side right under the tool box. Just use a little bit.
There is a drain hole just above the steering gear box that can get plugged up. Stick something into it every once in a while to make sure it is clear.
James
seanbarr
B7100DT (sold) - Branson 3520H
Feb 1, 2013
384
Deer Park, WA
Pretty much the first order of business is to get yourself a copy of the owners/operating manual and the service manual. It's pretty much worthless unless you get those two.
The second order of business is change all of the fluids (even the steering box) and go over everything. Make a note of what needs to be serviced, repaired, replaced, etc. I did that first thing with my tractor that I stole, err brought and it's pretty much complete save for the steering box which I'm waiting for a new steering shaft assembly as mine still "clunks" when steering.
Servicing the hydraulics is relatively simple, a novice could do it easily. If your 3 point slowly drops, new seals are usually the fix and is not difficult to do at all. My FEL wouldn't pick up the front of the tractor so new cylinder seals were in order and bam, made a difference. Oh, I'll bet that there will be crud behind the FEL strainer. If you don't know where that is, time to start reading and get the FEL manual as well.
In all, this forum is invaluable! Don't forget to get a bowl of popcorn and peruse the articles sections. It's a gold mine of information that you will appreciate and is fun to learn.
It's a great machine to work on if you're mechanically inclined!
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
If when you change the steering box fluid it looks at all contaminated or has water in it I would suggest removing and disassembly of the box. As seanbarr said the parts are expensive.
Sledge
B7001, Big B 4ft topper
Sep 17, 2012
37
Gloucestershire UK
James
Thanks. Steering box fluid change isn't mentioned in the owner's manual I have for the B7100. Fortunately I managed to get the workshop manual and you can work it out from there.
Damn, I thought I'd finished :(
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
I just understand why you would want to purposely drive it around knowing there's a problem with the clutch? Trust me I know the itch you get when you want to play with a new toy but patients does have a virtue. Last thing you need is to be on the back 40 of the 2 acre plot of land you own and the clutch completely goes out on you and you're no where near the shed to fix it.
That's when you find yourself up Shitts Creek without a paddle and no way to gimp it back to the barn to fix it.
chetcromer
Just got the B7100 back today, with the new clutch and bearing it's like a BRAND-NEW-new-to-me machine. What a difference!
No more roaring when holding in the clutch out of gear, no more grinding when shifting gears with the throttle above idle.
In the meantime I found owners and service manual for my mower and finish mower. Got new tranny fluid while she was in the shop so now just going to check the others and away we go.
chetcromer
Keeping this hear as it's related to my original post, but after about 2 hours of use (after checking / changing fluids), the roar is starting to come back when holding the clutch in, and the clutch pedal itself has to be pushed a lot further / harder to get it disengaged.
Could I have a pedal issue?
freewheel3
Mar 9, 2013
333
34
Alberta
I doubt its a pedal issue. Did they replace clutch, pressure plate and throw out bearing when it was in the shop?
chetcromer
Getting back to this after a week of family and friends in town.
There is a LOT of play in the clutch pedal - more than there was when I got it back from the shop. I'm going to re-grease the bearing and probably shoot a video of the pedal movement - it's like nothing is even engaging until it's pressed all the way down, and then it only engages a little bit. I basically have to idle the tractor and then shifting is the same with the clutch pedal pushed as when I don't have it pushed at all. Once in gear, pushing the clutch will not allow the tractor to come to a complete stop (i.e. neutral) without the assistance of the break or shifting back into neutral gear.
Would a video help you help me?
I know this is from another site, but I'm thinking my problem may be something like this:
http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=kubota&msg=25647
Or here:
http://www.orangetractortalks.com/forums/showthread.php?t=2469
Thoughts?
rednecklimo85
78 B6100E(brush hog, boxblade, snowplow) 85 B7200DT(loader and backhoe)
Oct 24, 2009
torrington,ct
Before going to crazy did you try and adjust the pedal? Worth trying it and not overlooking something simple before separating it again.
