Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 08-17-2010   #1
Dennis
1st Yr. Apprentice
Default B7100 Clutch pedal play and travel
just put a new clutch and throw out bearing in and I am now adjusting the clutch pedal rod, travel nut and safety switch nut.
Am I correct in my understanding that :
The" play" is the movement in the pedal (and throw out bearing holder) before the throw out bearing engages with the pressure plate.
The "travel" is the movement in the pedal from when throw out bearing contacts pressure plate to when clutch friction plate has disengaged from flywheel.
The manual suggests 2-4 mm play and 8mm travel.
I was a little surprised that I still had to adjust the clutch pedal adjustment rod to not a whole lot shorter than where I had it with the old clutch : i.e. now probably about another 5mm adjustment thread available.
Finally after running the new clutch in for a while I had to adjust the rod length a little. Is this normal with a new clutch ?
Dennis is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-17-2010   #2
ipz2222
Journeyman
Equipment: L235, bx2670
Default Re: B7100 Clutch pedal play and travel
You are correct on all points and clutch does need a readjustment after breakin.
ipz2222 is offline   Reply With Quote
Old 08-17-2010   #3
Dennis
1st Yr. Apprentice
Thanks for the advice
It's been a bit of a fiddle to set it up right and there seems to be a different sound to the new clutch.
Still can't figure out why I'm using so much of the adjustment out on the adjusting rod.
I had presumed that with new (and unworn) pressure plate levers I would be shortening the rod adjustment by about 6mm (1/4 inch)
My old pressure plate levers were worn down and uneven by about that much.
The forks didn't look that worn and surely the thrust bearing holder doesn't wear that much ?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
