Oil Pressure and Battery Charge Lights
countryhick
Kubota L2201
Oct 2, 2014
32
Monroeville, AL
I recently purchased a L2201 and neither of these lights on the tach work. I'm hoping the bulbs are just burned out. Can somebody tell me how to remove these to check the bulbs?
2,170
Not knowing that machine - has to be way to unbolt the dash panel and get down into it.......looked under to see if possible to drop the dash down ???
you have the manual by chance?
the tractor looks somewhat like a B7100 - see if you can get to the lights from inside the hood and look back upwards......
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
Your model is pretty darn similar to mine. Remove the 4 large screws that go down through the dash. Then you should be able to pull the dash up the column a bit to get to the bulbs. Mine uses a really small 2W bulb. Dealer wanted something silly like $10 each. Found them online for much less. I can get you a part number if you need it.
