oil in mower
mmmkay777
B7000
Jan 7, 2017
24
UK
Hi, I have an old mower. I was wondering if I need to top up the oil in the gear box?
This is a picture of the gearbox:
https://goo.gl/photos/wY94Fmge2DxjDJGb7
The nut at the top comes off and I can see the oil is about half full. In the manual it says 'check every 30 hours and fill as necessary' so do I fill it to the top ?
Also it says sae ep90 - can I use sae 80 in it?
Thanks
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
I would think that your manual should show a diagram as to the location of the fill/level plug which is normally located somewhere on the side of the gearbox. You would remove the side plug and fill from the top until it starts to run out then tighten both plugs back.
80W should be fine but I would prefer 90W.
Hope this helps.
mmmkay777
B7000
Jan 7, 2017
24
UK
Hi there doesn't seem to be another plug. Only the one on the top, none on the sides, the two other sides look like the one in the picture. Is it possible to overfill it?? Thanks
7,681
Then just fill it just to where you can see about 1/2 of the output shaft. Or make a dipstick out of a wire or something and guess where the fluid level is if you can't see. Make sure there is a breather opening somewhere (like on the fill plug) so fluid doesn't expand and cause problems.
mmmkay777
B7000
Jan 7, 2017
24
UK
Thanks for the reply. So the oil is about at that point so looks ok. Can't find a breather opening anywhere. This mower is about 35 years old I think. Should I drill a tiny hole in the top??
Thanks
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
I would not drill a hole.
Is there a plug underneath on the bottom of the gearbox unit ?
Is there a model, name, etc... on the unit anywhere or in the manual ?
