Oil Filter cross reference
Pepsiboy
BX2350D, FEL, MMM, Rear tiller
Oct 3, 2014
168
Shell Knob, Mo
Does any one know what the Fram or Wix filter numbers would be to fit my BX2350? Kubota numbers are HH150-32430 for the engine filter and HHK20-36990 for the Hydraulic filter. I have tried, but am unable to locate aftermarket filters to fit. These filters from Kubota Dealer have gone up to $16 for the engine filter and $19 for the hydraulic filter. On my VERY fixed income, this is hard to justify. I have located the fuel filters and the air filter aftermarket for $3 for fuel and $6 for air.
Thanks, in advance.
Dave
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
Gambrills, MD USA
Thanks, in advance.
Dave
Take your number, and tractor info to a good quality auto parts store. Most of the time they can cross it for you...:D:D
C15TA
170 Allis Chalmers , 580E Case & BX25D
Oct 1, 2015
Castleton ON
Dave, I got the oil filter HH150-32430 to cross to a WIX 51365 or a Fram 6607.
I stock that Fram number in my shop and I pay 2-3 bucks CDN. for them. WIX says there is no direct replacement at this time for the hydraulic filter and nothing will come up under Fram. Hope this helps.
Barry
Product Specifications
Part Number: 51365
UPC Number: 765809513655
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Enhanced Cellulose
Height: 2.58 (66)*
Outer Diameter Top: 2.69 (68)*
Outer Diameter Bottom: Closed:
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 300
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
( )* denotes metric
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 (63)* 2.173 (55)* 0.233 (6)*
FTG-05
Jul 21, 2013
235
86
TN
HH150-32430 = Wix 51365XP or 51365; Fram PH6607 or PH6017A
HHK20-36990 = This is a valid competitive part number and there is no replacement at this time. Had no luck with Fram or Baldwin as well.
Diydave
Oct 31, 2013
1,635
Gambrills, MD USA
This is just an FYI for other folks looking. You can go to either of these websites and type in your filter number and they will provide you with there part number ;)
http://www.wixfilters.com
http://www.framcatalog.com/application.aspx?b=F
CT15A, welcome to the forum... Darren, your links should go on the links sticky, if they aren't already there...
Re Hydraulic filters, I have a L2202, Shaffer's equipment can get the filter, but I took mine into a TSC, one snowy day, I had made a stub shaft, that fit the metric threads on the original filter, also had the measurement for the inner and outer seal surfaces, and sat there, pulling filters out of the boxes, and comparing the filters out, comparing the shaft and seal surface measurements, came up with a fram#3593A. While it is smaller than the OEM filter, but everything worked fine, after its installation, and its $7, rather than $50+ that the one from Shaffer...:D:D
4,531
They are up there, at least the Baldwin and wix sites are :D
ThisIsNotaStep
2005 bx23 tlb
Nov 26, 2010
133
Ontario, Canada
Pepsi .. I have the same BX, the engine oil filter is available almost everywhere, Walmart, C/T, TSC .. it is a PH3593A. I have not been able to find a hydro filter in any chart, or from any supply store. What brand/part no is the air filter you came up with?
PCDietCola boy.
Pepsiboy
Oct 3, 2014
168
Shell Knob, Mo
Diydave,
I have tried that at 4 different parts stores (NAPA, Bumper to Bumper, O'Reilly's, and Allied), they ALL said the same thing. No cross available for EITHER filter.
Dave
Pepsiboy
Oct 3, 2014
168
Shell Knob, Mo
PCDietCola boy.
ThisIsNotaStep,
Thanks for the reference number. I'll check that out next time I go to Wal-Mart. The fuel filter I am using is from Wal-Mart. I don't remember the number, but it is the same size and has the same size nipples to attach the fuel lines. It is a 5 micron filter for about $2.50 US. The air filter is a Fleet guard AF 25550 from NAPA for about $7.00 US.
Dave
Diydave
Oct 31, 2013
1,635
Gambrills, MD USA
Diydave,
Dave
Bumper to bumper has been able to get the filters I need on the old ones I have. Maybe yours is too new...:D:D
mattwithcats
774
65
