Oil Changes
LAN20514
PA
In any equipment I've owned, I've always changed the oil yearly. This year, I'm not going to come close to the recommended hours of use for scheduled maintenance. Just curious what you do? Change yearly or follow the maintenance schedule, even if the hours of service may be closer to 2 years?
SDT
Apr 15, 2018
3,690
1,414
I've always changed engine oil and filter yearly regardless of operating hours.
I do it in the fall after last use on seasonally used equipment.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,091
1,014
Amsterdam, NY
Neither your profile or your post states what kind of equipment you have so it's hard to offer specific advice.
Like SDT I change engine oil/filter once a year or by hours which ever comes first - just an old habit for me personally on all my vehicles - since it isn't that expensive to do so. The hydraulic oil/filter I change according to the ops manual recommendations, every other year so far.
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
434
302
Bayview Township
Engine oil and filter are relatively inexpensive. First tractor owned for the first few years I use to change the oil and filter annually. Never reached the manual noted hours. My neighbor use to farm and in retirement has started up farming again. He sort of laughed at my low hours and annual oil and filter change. I took his advice and started changing every other year which ended up around 100hr intervals. He was right. Couple decades of use the tractor was still running fine.
Traded it in for the BX in April of '25. Sticking to the manual recommendations until out of warranty. Then if still just running ~50 hr/year will revert to every other year for motor oil and filter changes. Which is basically what I'm already doing. Just broke 90 hours this past weekend. So only 40 hours since last Autumn oil and filter change.
JonM
L6060,SA20,4in1,BH92,QH16,BS40,APS1572,RTR2570,HR2572,WC1504,FM2584,SBP1684
Nov 29, 2024
282
677
wisconsin
year hours mileage depending on vehicle whichever is first. reason for yearly is it means your not running it enough and water from condensation can kill your oil
kcs 61
B2650 , BH77,FDR1660, PFL2042,RCR1860,RB1672, RTR1258,BB1260
Apr 8, 2024
71
29
Va
I do oil,oil filter and fuel filter once a year
