oil change L1500
AllenH
Alabama
hi everyone, has anyone ever change canister oil filter,Do you take canister off of tractor? I need help please advise! thanks
6,632
AllenH, if you have the replacement filter just remove the horizontal bolt. Be sure to have your oil catcher tub underneath. There are a washer, spring and a seal, if I remember correctly, on the inside. But just slide to housing off and replace everything in the order you remove it, after you clean the canister.
Tooljunkie
May 13, 2014
4,150
What i see is a bolt on the left end of canister,by loosening that and removing it, you should have a big splash of oil. Its too late to grab the oil absorbent material
As i have done before.
Your new filter, if an aftermarket one will have several gaskets. Just match up what you have on the old one. Wash housing and dry off. A little grease will help hold loose gasket in place while assembling.
