Oil change capacity
Bjones
L2800
Apr 23, 2017
46
walhalla, s.c.
Changed oil and filter for first time today in my L2800 and OM called for 6 qts with filter. I didn't think to check it after 5 qts since OM stated 6 qts but dip stick looks like it is maybe 1/2 qt to full. Should I drain some out or will it hurt to be slightly over full? Thanks
7,366
Keep it full on the dipstick. Common question, since OM seem to be a little off quite often.
Some tractors have multiple drain plugs. Sounds like you’re very close in quantity, so it doesn’t sound like you missed a drain plug.
Just fill it. Don’t overfill it, and enjoy!
Bjones
L2800
Apr 23, 2017
46
walhalla, s.c.
Yea mine has two drain plugs. SO would You recommend draining a little out to match dip stick full marking. Thanks for your reply.
SidecarFlip
Banned
563
Dip sticks can be inaccurate depending on how they seat. I'd leave it go if it's not radically overfilled.
Just changed the hydraulic fluid in one of my 2 M's. WSM calls for 52 quarts but don't say filter changeout or not. Installed 2 new suction filters and 52 quarts put the level at the top of the dipstick give or take 1/4". Good enough for me. I usually have to add makeup fluid anyway because I'm always loosing some from the hydraulic connectors being switched out all the time.
lugbolt
ZG127S-54
Oct 15, 2015
5,515
2,228
Mid, South, USA
The books are mostly wrong about capacities. I don't know how or where they got the info from but they're wrong.
SidecarFlip
Banned
563
Drain it to the full mark. I was always told it was very bad too have the oil over full.
By whom? A little bit over is no big deal on any engine
Pau7220
Aug 1, 2017
786
281
Clarks Summit, PA
You are corrrect. Most of today's dipsticks and owners manuals state "do not overfill". Overfilling causes aeration/foaming. Better slightly low than over. Of course full mark is best.
PA452
B2650
55
Western PA
This. It might be fine, but I'd probably try to get it to or below the full line.
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
Yup, you are better off slightly low, than over full. Oil aerating, which is what happens when the crank shaft spins through a pan of oil (which is where windage trays, and crank scrapers come into play). Bubbles of air cause cavitation in the pump, and air means low oil pressure at the bearings.
9,118
Had a customer call up complaining that there rental pump was using a quart of oil every 12 hours. Engine had an 8 gallon oil capacity, and was an old detroit diesel. Engine had to drop a gallon before it got to the add mark on the dip stick. I told them not to top it up at the 7pm check, and to check the oil when they came in, in the morning. Oil level never dropped below the one quart low spot on the dip stick. Told them to not worry about it being 1 quart low and to run the snot out of it :D:D
Some of those older engines would burn oil if it was at thel full mark on the dip stick, but would stop once it got a quart or two down.
SidecarFlip
Banned
563
2 stroke Detroits all had pressurized crankcases and deposited oil out of the valve cover breather tubes all the time. Why you never parked on on asphalt, always gravel as the always marked the spot....lol. Th older they got and the more blowby they made, the more oil came out the 'puke tubes'.
Had an 855 Cummins like that. Change the oil to the full mark and within a couple hundred miles it was down a gallon and stayed there.
2 stroke Detroits run best at rated rpm, why the make good generator engines and engines in constant rpm applications like pumps. Detroit engines don't like to idle.
4,249
Engineers determine the amount of oil the engine needs for operational lube and cooling. They add to the design to provide for long-term consumption so that the engine never suffers from lack of lube/cooling between service. This results in the "correct" amount PLUS a reserve.
If MORE than the "reserve" is installed, the crankshaft can become an "egg beater", especially on slopes or during accel/decal events. Once the oil becomes entrained with air (foam) both lubrication and cooling needs are no longer met.
NEVER overfill with oil. If inadvertently overserviced, drain or suction out the excess. REmember, the design accommodates a reduced oil supply but NOT an overserviced sump.
SidecarFlip
Banned
563
Pretty hard to whip the oil in a Kubota engine in as much as the crank is supported by a cast 'girdle' on the bottom of the block. You'd really have to overfill it to reach the crank.
Interesting comment on your part in as much as most small engines have no oil pump and 'whip'the oil around with a paddle attached to the con rod
called 'splash' lubrication.
SRG
Jul 15, 2017
490
N. IL
That's an interesting comment on your part.
The reason, is simply because those small engine don't have an oil pump. That's how that design is able to get away with splash lubrication. It's the aerating of oil that causes cavitation in the oil pump and will cause it to fail. No oil pump, no worries.
3,160
One thing I have noticed on my old L185 is that the oil will drain out of the filter over a short time and then the oil registers slightly high on the dipstick. Start and run for a bit then let it set for an hour and it reads full like right after an oil change.
You may want to check yours and see if it acts the same (and be more unsure about what to do!)
Pau7220
Aug 1, 2017
786
281
Clarks Summit, PA
My land is so sloped I easily end up at 45* angles when mowing up and down the hills. I'm sure I'm bumping some of the oil at times... overfilling would only make it worse.
P.S. Geo.... Eggbeater is a great description :D
Pau7220
Aug 1, 2017
786
281
Clarks Summit, PA
Check valve in the filter should prevent (or at least slow) this. Is it a Kubota filter? Does yours have a check valve? Not all filters do.
4,249
This is an excellent reminder that cheap oil filters can contribute to problems. Cheap oil filters often use stiff, ineffective back-flow designs. Better filters use materials that do better at keeping the oil ready for use instead of letting the oil escape back to the sump. (Often it's a cheap nitrile flap in the aftermarket/cheap filters and it's an EPDM/Silicone part in the better filters. The cheap materials lose elasticity when things cool down and let the oil escape. Then, when the engine is re-started...the filter does not have oil ready to supply...instead the filter requires the pump to re-fill itself before the engine is supplied.
This means the engine is making perhaps a hundred revolutions without full oil pressure if the cheap filter requires re-filling.
