OEM Work lights to LED conversion
tinman4240
Kubota L4240 HSTC FEL BH-92 hoe Pronovost P-720 SB HLA 1500 6' pusher/backdrag
Feb 1, 2015
30
South Windsor, CT
It is less about the light, more about the placement!!
Lights should be placed BELOW your line of sight for the least amount of glare/reflection from snow or rain.
Hey Orange1forme, I'll keep your suggestion about line of sight in mind. I'm thinking I'll have to tweak the angle downward a tad.
tinman4240
Feb 1, 2015
30
South Windsor, CT
I had a similar experience and was told to use better lights, just like you.
I replaced the front overhead lights with a cheep set of LED's and I put a cheep LED on both sides of the cab for snow blowing at night. The cheep ones light up the area great but as soon as I turn them on I lose my radio reception. I have researched a lot and have tried a few different things but still no radio with lights on. I am told the more expensive LED's don't run on the same RF frequency as the radio's do. I can bluetooth music to my radio when running at night so I can live with it.
Thanks tinman4240 those look great. I saw today they were on sale. I’ll be plowing snow tomorrow and Tuesday when lake effect settles in.
I’m going to order in next couple days.
Hi Pokey1416 That looks like a fair deal. I paid $95 + $5 shipping each so if you want them, go for it. TigerLights are supposed to be good stuff. Good luck
tinman4240
Feb 1, 2015
30
South Windsor, CT
If price = quality then I'm on track. I suppose that is not true with everything. We'll see what happens. There are a million different LED's out there to choose from. I took a chance and paid dearly for them.
Orange1forme
Dec 1, 2018
397
60
Wa
I bought Nilights, which I was told were a better brand.
Brankor
2018 - L4060
Nov 26, 2020
22
Sudbury Ontario
Hi
I ended up installing some clip on Ferrite rings cores --- I clip them on the lead as close to the LEd bulbs as possible -- I installed 2 ferrite per lead and fixed my reception problem -- Radio is back
Purchase them on Amazon
tinman4240
Feb 1, 2015
30
South Windsor, CT
I got over 6 hrs seat time at night dealing the slush and water saturated snow 12/5/20 using the 4 LED work lights I recently installed on my L4240hstc. Compared to oem lights, much more illumination about the work area. Did not notice any glare from falling rain and snow. I might try rotating them a bit downward but they are floods. Not like you are using a spot. All in all, if they last and go on when I need them, then I'm satisfied.
BTW, the Pronovost P720 I run on the back just clogged with slush and was almost useless. Snowblowers, in general, do not like slushy snow. Thanks to the HLA 1500 pusher with the poly back drag option, I got it done.
