Not sure where to put this
dce
L3540, loader, mid-mount mower
Nov 9, 2012
19
minot nd usa
brand new grand L3540 this fall in october. Minot ND, Acme tool supply. Got it home antifreeze leaking. They fixed. AC, not working they said they would fix. Now, out pushing snow front left tire come off rim. Lemon???? Head bolt heater put in on left side, as sitting in seat. From what I read on here that is wrong. Any advice?????
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Its under warranty and they are supposed to fix it all. And like anything else you buy you can get a bad one every now and then.
hodge
Nov 19, 2010
2,959
529
Love, VA
It sounds like you got the lemon in the bunch. That doesn't mean that the tractor is bad, but that you have an unusual amount of issues. If I had put down good money for it, I would have a sit down with the dealer and a Kubota rep. Even if they are willing to fix all of these things now, who knows what will rear up in the future? I would express my concern about the high number of issues, and that I am now lackig confidence in the tractor. I bought Kubota because I had confidence in it, and now that is shaken. I would prefer that they issue me a new tractor, but if not, I would want them the extend the warranty, and keep my tractor on the radar.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
When I bought my first Kubota 35 years ago I ordered a front pump for the loader. The dealer couldn't figure out how to mount it, and ended up taking a torch to the hood mount to get it in. Then in short order the mis-aligned pump shaft broke. They bought me a new pump, and I figured out the mount. Tractor has run great ever since.
This sounds like a poor prep job. They should know how much air to put in the front tire. OR, it shouldn't leak out. They should check the A/C. And they should check the antifreeze and cooling system. None of it makes a bad tractor. But it sure sounds like a poor dealer.
pmhowe
L4240, Ford 8N, Kioti CK 2610
Jun 23, 2012
117
Banner Elk NC
" Head bolt heater put in on left side, as sitting in seat. From what I read on here that is wrong. Any advice????? "
I'm not familiar with your model. However, according to TractorData, the L3540 has a 3 cylinder engine. The block heaters are typically installed on the left hand side of the 3 cylinder engines. It is only on the four cylinder engines that the heaters should go on the right hand side.
I doubt you have a lemon. However, I think it would be well worthwhile for you to go over your tractor carefully. Check all fluids, check loader and wheel bolts, and torque them to the manual's specs. On my brand-new L4240, I was surprised to find that the real wheels weren't properly torqued, the front axle was less than half filled with hydraulic fluid, and the main transmission was also short on hydraulic fluid (well below the "must fill" mark).
The dealer I bought the tractor from obtained it from another dealer. Apparently, neither dealer did a thorough job of going over the tractor. In a new car dealership, this would be totally unacceptable. Kubota dealers apparently don't hold themselves to as high a standard, which is disappointing.
TripleR
Sep 16, 2011
1,911
SE Missouri
What Kuboman and other said, I would be sure to make the dealer fix it, but you do need to keep track of tire pressure wheel torque and things like that. We are on our fifth Kubota and fourth new one. The first one was poorly setup and had some problems, the other from a different dealer have been trouble free.
Yes, everyone makes a lemon, but I don't think you have one.
TripleR
Sep 16, 2011
1,911
SE Missouri
Did you say fifty as in 50, like 48 49 50???
Glad you caught that, "senior moment", should be fifth, I am getting use to the keyboard on a new computer and bouncing back and forth between it and my old one, sorry for the confusion.:(
dce
Nov 9, 2012
19
minot nd usa
Thanks for all the input. The guy I deal with is very nice and has done everything to help. Just frustrating to buy something brand new and have as many problems. I still love the tractor and hope the problems end soon.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
As aggravating as it is be thankful the dealer has stepped up to the plate to address the issues and fix what's wrong. We've heard on here all too often that people buy a brand new Kubota and go threw hell and back trying to get their crappy dealer to honor the warranty work. Sounds like everybody wants to sell them but nobody wants to fix them!
