New LX3310 owner checking in
kubotter
LX3310HSDC Cab w/LA535, LX2963 Blower, Box Blade, Tiller, Forks, Brush Hog, Rake
May 28, 2021
10
Wisconsin, USA
Huge thanks to everyone here posting in this forum. I didn't register until just today, but have been lurking/reading for a couple of months now. All of the information here helped me spec out and now take delivery of my new LX3310HDSC (cab model).
I'll be watching and posting as I learn more, have questions, or can give info/pics to someone needing help.
Thanks again.
Bmyers
May 27, 2019
3,173
3,663
Southern Illinois
Congrats on the new tractor, looking forward to seeing pictures of it.
Old_Paint
Dec 5, 2020
1,561
1,458
AL
Think you're gonna love the new tractor. I got the LX2610, and it's the biggest little tractor I've ever driven. It's a good machine. I've enjoyed mine immensely since I got it. Welcome to the site. Lotsa good folks with good info in here.
kubotter
May 28, 2021
10
Wisconsin, USA
2 days in and already turned double-digits on the hour meter :oops: I'm sure that will slow once the newness wears off some, but very fun being out there so far. Main task now has been using the box blade to smooth out some old farm-rutted field where a driveway will eventually be going. It was a suspension/teeth filling breaker and the box blade made it much much better already. I still have some learning to do on top-link angles and ripper shank depths, but still made do.
PaulL
2,138
1,133
NZ
Nice work. Jealous. I'm not getting enough seat time at the moment.
Snowman7
May 20, 2020
348
246
Boyne Falls, MI.
Let us know how the first regen goes, rpm you were at when the light came on, timing and such. I did the same thing with mine for a half ass food plot ( box scraper ). Enjoy!
kubotter
May 28, 2021
10
Wisconsin, USA
Had my first regen tonight right at 17.0 hours. It was right after a cold start, RPM light was blinking until I was above 2200 RPMs. Took 19 minutes which didn't bug me at all because I had work to do anyway.
dkpricer
LX3310
Jun 26, 2021
Graham
Hopefully mine comes in some time this year. I ordered the same tractor Saturday. Very much looking forward to having it around the place.
kubotter
May 28, 2021
10
Wisconsin, USA
After dealing with all of the Covid/supply chain delays for everything over the past year, I was beyond shocked when the dealer 10 minutes away told me that they had a LX3310 Cab model in stock. I couldn't put down a deposit fast enough. I was expecting to have to order and wait months, and feel very lucky to have had one actually in stock nearby. So far it is a great machine for me and for you it will certainly be worth the wait.
dkpricer
LX3310
Jun 26, 2021
Graham
NICE! count yourself lucky!
Hopefully the tractor can be delivered sooner than the estimate the dealer gave me
PortTackFarm
L3560 LE (ROP's) w/ LA805 FEL, LP RCF 2072, BB2572 and WoodMaxx WM-8H
Jul 2, 2021
124
124
The Ville and The Farm (KY)
Looking for a new Kubota for our 44 acre farm (mostly wooded with some steep hills) and I'm between the L3901 and LX3310. I am planning to also include Front End Loader, Box Blade and Rotary Mower or possibly Mid Mount Mower if I go LX3310 to the full package. Any thoughts and recommendations either way?
S-G-R
LX3310, LA535, rear remotes, third function, R14's
Jun 17, 2020
910
1,635
PEI Canada
I'm getting tired of crawling under my LX2610 to clean and grease the deck. How much grass are you planning on mowing? Maybe consider a rear finish mower.
PaulL
2,138
1,133
NZ
Rear finish mower can tend to be wider. For big open spaces, that'll do more work in shorter time. But mid mount mowers are easy to use. I take mine off all the time, no idea why you'd crawl under to grease one. I had mine off today for some tractor work, put it back on. Takes less than 5 minutes off and on, and no significant bending down. On the BX it was a pig of a thing to attach the drive shaft because the machine was so low. On the B2601 it's really no big deal, it's so much easier. As for cleaning, I use my stihl blower. No need to crawl under for that either.
The L is a bigger, stronger machine. The LX is lighter, but can be ballasted up when you need weight. The LX suits people who need a lighter machine - for driving on the lawn, for putting on your trailer. But if you're going to fill the tires, it'll be heavy either way - so if you need a light machine it probably also means you're not filling the tires. Horses for courses. If you're not weight limited the L will do more and it's a similar price. You get more metal, fewer features.
S-G-R
Jun 17, 2020
910
1,635
PEI Canada
I agree a mmm is easy to take off however, with a shoulder injury not so enjoyable getting the pto shaft back on.
SDT
multiple and various
Apr 15, 2018
3,084
926
SE, IN
Does the LX3310 have a DPF monitor, i.e., bar graph showing soot accumulation, like the GL series does?
My B3350 does not so there is no way to know when it is going to regen. Because of this, I find myself going to inhibit mode often to avoid regens during inopportune times, e.g., work done and heading back to barn, changing implements in barn, etc.
Regens are annoying unless performed (and completed) while working.
SDT
kubotter
May 28, 2021
10
Wisconsin, USA
SDT
No DPF monitor/meter on the LX3310. I read the regen section of the manual several times and it still doesn't make much sense to me. Thankfully I got the 1st regen alert/warning right when I started up for the day, so it really didn't inconvenience me at all. However, if I were to get the alert as I'm heading in for the day, and need to go to an appointment, I won't have 20 min to sit there while it does its thing.
Is that one of the uses of the inhibit button? I would get the regen alert, then hit the inhibit button and I don't have to worry about it until the next time I start up? That would be nice. Or is the inhibit button something that I have to turn on proactively? Like if I know I have somewhere to be and I feel that a regen is coming that day based on hours, I would turn the inhibit mode on maybe ~30 min before I need to leave just in case?
