New carburetor for a Kubota AV6500 generator
RandF.F.911
Kubota AV6500-B-USA Kubota G1800 riding lawnmower
Mar 10, 2023
Oakland, Michigan
I purchased a used Kubota AV6500-B-USA Generator yesterday, It was listed as, needs carburetor work for $250 I figured how could I go wrong, when I looked at the generator I noticed the float bowl hanging below the carburetor, the F.B. gasket was leaking The previous owner over tightened the the bowl retaining bolt and broke the internal threaded housing in half. its a Mikuni Carb. #12008C below that number is 2 V651 looks like the Kubota P.N. 320400 does anyone know where I can find a used carb or know of any manufactures that used this style of carburetor on their engines? I searched for the Mikuni numbers with no luck, this generator only has 25 hours on it, He told me it was his grandfathers and it was purchased in or around the yr. 2000 if I can find the upper carb housing to match, I can transfer the jets and other carb components I’ll try to post some pics Thanks for any help
9,145
The Kubota PN is EG356-44010
Your chances of finding that carburetor is slim to none.
While these two have listings for them, it's highly unlikely you can get it.
Check you dimensions against this model carburetor, it's way cheaper, and you might get lucky.
RandF.F.911
Mar 10, 2023
Oakland, Michigan
Thanks for the info, I did find the Kubota P.N. for the carburetor 12008-44040 $500-$600 and N/A I was hoping Mikuni made the same casting for other small engine manufacturers, but once I realized that China Isn’t producing a replica for $15 I thought to myself, once again I must’ve been intoxicated by the color of orange, and used poor judgement, I knew I was rolling the dice, this Generator looks like it rolled off the showroom floor, and only having 25 hrs on it, and no Circuit board that cost $400 to replace when it burns up a day after the warranty is up, along with a 2 hour drive to buy it,, I better start looking for something that bolts on and can atomize fuel, otherwise it’s looking like Snake Eyes with the dice, unless a kind member has a old carburetor from a AV6500 generator laying around, that they no longer need, and would like to donate or sell it for a reasonable fee
Thanks again
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,382
1,970
WestTn/NoMs
You could try shade treeing it.
Find a bolt the size and thread of the bowl bolt.
Clean/sand all around the broken area.
Lightly oil the bolt and place it in the remaining threads.
Use J B Weld to replace the missing part. I would find a short piece of metal tube to slide over that area to reinforce it and help mold the epoxy.
When it has hardened, remove the bolt and grind or sand off any excess.
Install the bowl and bolt. Check the bowl level and needle valve first.
William1
BX25D
Jul 28, 2015
1,243
440
Richmond, Virginia
I'd take the old carb to a motorcycle bone yard and try to find a decent CV carb that matches for bore, i a flange mount and throttle location.
9,145
5,179
3,636
I suggest you take the easy way out…. and convert it to LPG (propane)… a simple matter of a small copper tube stuck into the intakes and a thumb-screw for a regulator…. 😜
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
James condon has a you-tube channel, where he repairs generators. He seems quite knowledgeable, you could try contacting him, and hearing what he recommends.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,010
1,388
Pittsburgh
RandF.F.911
Mar 10, 2023
Oakland, Michigan
I would like to thank everyone for their input, I‘ll post a few more images I do have a few questions from the responses starting with, Is JB Weld resistant to solvents ie: gasoline? if not can anyone recommend any kind of epoxy that is resistant to solvent? I do have some bushings that I could use as a sleeve, I used a 3/8 piece of pipe and used JW Weld on one end with a lubricated bolt and the same on the other end with some 608 Clear Epoxy patch. I was going to soak it in some gas to see how well the epoxies hold up, my other question is about the propane/natural gas conversion kit, i’m not familiar with these conversion kits, can anyone recommend a company that sells them, would I still need a carburetor? I’ll attach a couple pic’s of the carb’s bolt & bore openings just incase someone might have a carb that they could recommend. And a couple pics of the intake manifold to see how I could add a Multi fuel set up, And thanks Wolfman I did look at the carbs you recommended but they were to small. Maybe I could Ck. To see if theres A Mikuni carb forum, I would probably have better luck finding the stock carb, Thanks for all the suggestions
25384AA7-3551-47F6-A1AE-15A88D5CEA88.jpeg 692B4CBC-71A6-4ACF-8953-E86E19834013.jpeg 3F62E902-A834-4E07-AC20-81A1CF9C1B73.jpeg 3F87AF8C-A07A-44EB-B89E-362A18BA92BA.jpeg BD52052D-72AC-4024-897E-1340160D977A.jpeg
5,774
'JBWeld ' is a mixture of epoxy and steel filings, so 'ok' for gas.
as for replacement carbs... check similar power(HP) gas engines.
Years ago,super rush job, guy needed a carb for his Honda 9HP motar mixer. $250 for Honda carb,3 day del. I bought a 'Chinese clone' for $250, tossed carb on Honda, up and running in 3 hours (still using it 5 years later...)
Let Google be your friend...trick is putting the right 'keywords' in the correct order, to narrow down the results.
5,179
View attachment 97889 View attachment 97890 View attachment 97891 View attachment 97887 View attachment 97888
What a magnificent looking new piece of machinery you have!
Yes......JB Weld is fantastic stuff, and is unaffected by gasoline.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,382
1,970
WestTn/NoMs
JBW is steel-reinforced epoxy. Should be fuel resistant, their site has a gas tank repair technique. But it uses the putty style which I'm not too keen on.
If the threads don't hold, you might embed an insert.
Century sells dual- or tri-fuel conversion kits. I have no experience with them. You still need the carburetor, maybe not the fuel tube, etc. The auto idle might still work.
3,636
5 years ago I repaired the aluminum elbow exit from my Kubota M4700 fuel filter/ water separator which kept leaking because the elbow was only pressed-in to the valve assy. This is a common Kubota type filter. JB Weld fixed it permanently. JB Weld is gas, diesel, oil, fuel-proof.
partsguru
generator
Feb 5, 2025
berwick,pa
[/QUOTE
ARCTIC CAT USED THE SAME MIKUNI CARBURETOR ON THE GP7500GD2E GENERATOR 1999. YOU CAN GET A OEM REPLACEMENT CARB $325-$565 DEPENDS ON WHO IS SELLING. I'VE RESEARCH THIS CARBURETOR OVER MONTH NOW FOR A CUSTOMER AND WAS SURPRISED TO SEE ONE ON HERE(HOPING FOR SALE) GOGGLE ARCTIC CAT PART #0693-586 (13200-92A50). REMEMBER ARCTIC CAT JUST WENT OUT OF BUSINESS AND THEY HAVEN'T SOLD GENERATORS SINCE 1999. GOOD LUCK.
partsguru
generator
Feb 5, 2025
berwick,pa
THE KUBOTA PART # FOR THE CARBURETOR IS 12008-44040 AND I FOUND IT IN STOCK AT PRICING.PARTS.com(usa) price is high $786.89. if you still need it.
