Hi all, I'm working on a 2005 B7610 for the first time in a semi-serious way and am having trouble with the info in the manual vs the info online. The manual indicates there are 2 drain plugs (beside each rear wheel) but many others refer to either 3 or even 4 plugs. I've located what seems to be 2 additional drain plugs but I'm not sure if they are - and if they are, where do I refill the fluid that drains out? Does the fluid from the trans flow all over the place? Or are there other fill points?
BTW - I'm changing the fluid because it has been left out for the past 8 years and seems to think it's part boat. The hydraulic fluid is milky and I can't think it's anything other than water mixed in. After letting it sit for a few days, most of the milky part seems to have settled to the bottom of things.
Thanks
Thanks
