I know that this is a Kubota forum, but I guy I share hunting land with needs some help and cannot seem to find it anywhere else. I thought maybe someone here could help. Anyway, the tractor is a Deere 2020 made in around 1968.
He had a leak on his fuel line. The tip of the line was damaged through age not accident and fuel was leaking at the engine, not pump. When the fuel leak started the tractor would lose power and run rough. Prior to this he didn't have a single problem with the tractor. After he was finally able to secure a new line we began the process of putting the new line back on--with the help of the old farmer we lease the land from, who actually has one of these tractors as well (and several others) and is very familiar with this machine.
We put a very small washer on each side of the male banjo bolt where it contacts the female side (although he only remembers there being one on there when he took it apart--Deere guy told him he needed two--one on each side) and got it back in successfully. Now, where this line connects to the pump is nearly impossible to access, in fact we had to bend a wrench just to get to the banjo bolt head (see photos below).
Finished, started up like a champ and ran fine for a day. After that its hit or miss. Sometimes it will run fine, for a hour or so and then struggle with low RPMs and running rough. When it struggles if he loosens or tightens the bolt slightly (back and forth each time) seems to run fine for a while and then the same problem. Now, we were told that the "holes" of the banjo bolt do not need to line up as the fuel actually fills in a gap in between.
If anyone has any suggestions or ideas it would be appreciated.
