the engine oil pressure lamp isn't working and also does the b7100 have a water pump and is there a way to put a water gauge on the tractor.
cb sent you two great links....
but to answer your questions, there is NO water pump, thermosyphon is basically HOT water will rise and cooler water will fall, thus self circulating! The bad new is, if you get too much grass or dust in your radiator, you are screwed,blued and tattooed !
I too am in the process of adding a temp gauge, looking to cut the top radiator hose, place a $6 alum T inline and adding an electrical temp gauge. Total cost will be about $25.
When I cut grass I am constantly getting off the tractor to check the front screen which is alllwaaays full of grass, the fan draws it in at good clip, this way I can glance down and see how hot the hot water side is and then clean as needed.
