I started to use my B7500HST to do a little driveway work hooked up the boxblade got half way to the end of the driveway and heard squealing and smelled burning rubber, got back quickly to the garage and the Dino bearing(s) had seized up. Having a friend put new bearing(s) in and we should be back to normal.
Question is there are two blue wires (no tracer colors or markings) coming out of the dyno with the same type of connectors on the end of the wires. Are these the same 12v output so when I reconnect to the two mating connectors on the tractor does matter which one is connect to which connector? I don't want burn up any thing.
Does anyone have the wiring schematic for this tractor also.
Thanks
Thanks
