My log splitter tires….not Kubota but I need help!
Firstgear
L3560LE, Grapple, bucket, snow plow, forks, stump bucket
May 16, 2023
112
122
Kennebunkport, Maine
My log splitter tire kept going flat so I decided to have the tire guy put inner tubes in both about two weeks ago. Went into back garage today and now both tires are flat. I am tired of having keep fixing those suckers. I don’t want to put liquids in the tires, are there other options that I can try?
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,441
1,733
Kalamazoo, MI
Some of that stuff on Good Works Tractors that you can drive spikes into the tire and it seals up. Can't remember the name of the product at this moment.
9,586
FYI your not putting liquid into the tire your putting it in the tube! 🤪
WAS BANNED FOR NSFW PICS
5,157
I posted last week about the Kubota tire sealant that is water soluble and seals both the bead and the tire.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Tire shop might be able to fill them with foam. No more flats.
5,157
Have you priced what it cost to foam fill a tire today? More than the cost of buying a new tire and rim at the list price from Kubota.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Nope. Must be pretty expensive then. I didn’t know there were precious metals in the foam.
It’s a log splitter. Are we talking about a 12 inch tire or a 14.9-26?
Took a quick Google look, foam filling makes a $100 tire cost about $200. So maybe not a super crazy solution.
BX23-S,57 A-C D-14,
5,872
'log splitter tire' ?
curious....
OK off road use only or do you tow it on the highway ??
WHY are you getting flats " thorns or nails ?
Are you towing splitter to trees or does it stay next to barn ?
what size tire and rim ?
If strictly for 'No Highway Service', you can buy 'flat free' tires..problem solved.
4,292
Has anyone actually used this?
It looks "too good to be true".
My Google-Fu is weak today and I can't find out much about it, like
1. Does it actaully work?
2. How much do you put in each tire?
3. Can you use it at highway speeds. (i.e. on you trailer or truck tires)
I found it at Messicks for $82 per gallon, but would like a little more info.
9,853
curious....
I agree. Solve the root cause of the problem rather than apply band aids, even if that means going with a different system. The tire without a tube "kept going flat" and now the tires with tubes "are bot flat". There might be a clue there.
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
I know you said that you didn't want to use liquid sealant, but I've been using TireJect on my tires and it just plain works. Everytime. I have it in my log splitter tires, Gorilla wagon tires, ATV and side by side tires. It's never failed to stop a leak. It also seals future punctures. My tires with this in it never go flat, period. I've used Slime before with moderate results, but my results with TireJect are flawless.
tireject.com/collections/off-road-tire-sealant-products
Smokeydog
Jun 2, 2020
757
728
knoxville, Tennessee
The wheels on my 30+ year Northern Hydraulics splitter had too much weld splatter for tubes to fix dry rotting tubeless tires. Many cheap tire options. Finally ordered some Kenda brand. Easy twice as heavy built as the original. Been trouble free for 8 years now.
Nothing kills the day like a flat tire.
BX23-S,57 A-C D-14,
5,872
one possible cause for 'always going flat', it not ensuring there's the correct air pressure (or a tad more) in tubeless tires on equipment that's not often used (aka 'seasonal' ).
Firstgear
May 16, 2023
112
122
Thanks everyone for your comments. I bought two new inner tubes and took them this time to a different place. I only went to them because they were closer but this time I took them to the shop I get my tires from that is in town.
I spoke with the guy who will do the work and asked him to pull the tires off of both and check the wheels for anything that might cause an issue for the tubes. I feel I am in better hands now. They will also have the tires for about 10 days and if they do the work early in the week they should see any flats before I get home.
