MX5200 loader capacity problem?
GamblerAcres
50
2018 Kubota Mx5200 HST with 87 hours. Over the past few days I put some serious use on the loader for the first time. I moved about 30 tons of clean dirt that had been sitting in a pile for about 3 years. I also moved about 20 tons of crush and run gravel that had been sitting for over a year, compacted by horses (yes, they loved climbing it).
The piranha tooth bar made it easy to cut into the piles. My concern is that whenever I got a good bite into either pile the loader would stop lifting or curling. I've read many posts that the MX series will easily lift the rear end, even with plenty of rear ballast. That never happened, not even once.
The only ballast I have is a 3 point drum filled with concrete and blocks. I estimate it to weigh about 1400 lbs. The rear tires are NOT filled, nor do I have any wheel weights.
Normal or do I have issues?
7,102
You might want to look at some YouTube video to show the proper use of loading a bucket. Sounds simple, and is once you see the correct procedure. It sounds like you're setting the bucket down low and trying to push the bucket through the pile. As you push into the pile, raise and roll up the bucket to get it full. Takes a bit of practice, but after a bit you'll get the hang of it.
9,586
Your hydraulic pressure setting could be a bit low, you can get a gauge and test it. ;)
GamblerAcres
50
You're probably right. Regardless, the rear end should lift up when I try to lift too much based on several other posts I've read about the MX series. There are guys saying that filled tires, wheel weights, and an implement on the 3 point are not enough to keep the rear end down. I'm worried I'm missing out on power that I should have. I went with the MX for the loader capacity.
I think I'll go ahead and invest in a pressure gauge to be sure.
russell.still.5
197
Lafayette, Alabama
If the tractor is pushing in to the pile, the loader it's not going to raise. Same thing if your holding the brake with the bucket in the pile. The loader is trying to raise and push the tractor backwards. The loader raises in an arch motion, not straight up.
Sent from my SM-G960U1 using Tapatalk
troverman
Jun 9, 2015
1,178
264
NH
How much weight do you have in the bucket? I have an MX4800 which has the same loader and lift capacity as your 5200. I have filled Ag tires on the back, and a 600lb brush hog. With forks instead of a bucket, I attempted to lift a 275 gallon water tote out of the back of my pickup, filled to 90% with water. The tractor was unable to lift the tote, nor did it lift the back of my tractor.
In reality, your lift capacity is probably around 1500lbs. Which bucket do you have? I have the "light materials" bucket which is considerably larger in capacity than the standard or heavy duty buckets offered. In other words, if I loaded the "light materials" bucket with something heavy, I could probably overload it.
smittydog27
L3901DT, MX5200DT, Case 450, 1450 dozers, Case 530 const. king backhoe/loader
Dec 11, 2018
22
Huntington
275 LBS of water is 2,295 lbs.
Loader is model 1065
Loader is rated for (1065)*2.2= 2343lbs (book says 2275 lbs)
With forks extending out, I would say your at/above your max capacity
Steve
troverman
Jun 9, 2015
1,178
264
NH
Steve
No doubt, but the tank wasn't quite full. Probably 90%.
N7HEVN
MX5200, RCR2672, BB1572
Sep 12, 2019
40
Carrollton TX USA
Steve
Hi all.
A bit of revive on this old thread, I have a MX5200 as well, and was doing a Forum Search about loader and weight items, and have to tease ole Smitty there...
By your logic.... So, what's heavier, a pound of lead, or a pound of feathers....?
"275 LBS of water is 2,295 lbs"
I kid, I kid! Am sure you meant to say, 275 Gallons, not LBS !
For most liquids, like Water, I've always been told is 1 Gallon = 8 Pounds, which is a rough calculation against what you meant there, I assume.
Boo
MX5800; BH92, BB2572, Forks 3048
Jul 1, 2016
123
HOLT, Florida
I have the MX5800 but the same loader. With the rear tires filled and the backhoe on, trying to pull out small trees, my loader will lift the rear tires off the ground. However, when I drive into a pile of dirt and try to lift, it will not. I think it is a geometry issue.
