MX5200 3pt hitch
bullet225ho
mx5200, land pride 6' rotary cutter, 48" pallet forks, Tarter 6' Rotary Tiller
Apr 19, 2019
Fort valley, GA
Wolfman is correct.
It's a Cat 2 hitch. I've been replacing hitch pins on some of my implements as they came with Cat 1 hardware. In some instances you have to use a sleeve that goes over the Cat 1 pins to take up the space for the cat 2 hitch. I don't really like that scenario but it has worked in cases where I can't get a Cat 2 pin to work on such implement.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,236
150
Coyote Flats,Texas
I'll add to what others stated that sway bars can also be adjusted to either pin spacing width of Cat ll(34'') or Cat l( 28'')
