Folks, new to the forum, but have been a follower and reader for some time. I have a farming background, mostly john deere 125+ hp tractors. I ended up with a kubota MX5100 tractor about a year ago and use it for bush hogging, box blading, small disc, and small field cultivator.
My question involves the lift arm adjustments on this tractor. With a deere, I could always hook and go. With the Kubota, I have to move the side link pin locations to raise and/or lower the lift arms depending on what I hooking to. With my MX6 cutter and disc harrow, the side link has to be in the upper holes so that the implement raises enough off the ground. With my box blade and field cultivator, they have to be in the lower holes where the implement will go down far enough.
Yes, I have checked the raise limit linkage.
Is there no a "sweet" spot or modification for the lift arms? One of the side arms is screw adjustable, so I thought by adding a second screw adjustable (part # please), it may be better than moving the pins. I've also thought that if I move the side links back and create another hole in the lift arm, I may get the down range I need and an increase rise by means of the increased arch.
What are your thoughts?
