Hi folks,
When I turn the key to start, the fuel valve opens, the glow plugs get power, but the starter solendoid does not close. So the interlocks seem to be ok. Also the starting relay tests ok. Here's the real mystery - I measure 13 volts on the wire to terminal 1 of the starting relay (this is the side of the relay going to the starter solenoid) when the key is not turned. When I put a probe on this wire and accidentally shorted it to the chassis, the fuse for the high beam relay blew. Why in the world is the high beam relay connected to solenoid side of the starter relay? A similar question came up in this forum on 06-17-2011 concerning a B2320.
