Mower Removal - Decoupling the U Joint
foxnut
B7100 HST
Dec 28, 2012
11
Livingston County, MI
Gents,
I just purchased a B7100 HST with a RC60-71B mower. Been wanting a Kubota for a long time and am tickled to death with it. However, I wanted to un hook the mower today and had fits with the U Joint and couldn't get it to decouple from the PTO shaft. I followed the directions in the manual and disconnecting the front link and the rear links was no problem but I couldn't get the U Joint coupler to decouple from the PTO shaft. Any "tricks of the trade" that I can use or advice for a dumb newbie? Thanks:)
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I have never used one but does it unhook like a shaft does on the rear pto? I have seen them get stuck before due to not being properly lubed when they were initially hooked to the tractor.
meanjean
Kubota MX4700
Aug 10, 2010
922
Hazelridge, Manitoba
Liquid wrench or something similar.
Some attachments use a push button affair, others use a collar. Have someone work the release while you tap the connector backwards with a punch and hammer.
I've had this same problem and loosened it with the method as laid out above.
foxnut
B7100 HST
Dec 28, 2012
11
Thanks for the tips thus far. It has the collar that is suppose to slip rearward to decouple. I didn't think about trying Liquid Wrench to see if I could loosen it. I don't know how long it had been hooked up to the tractor. Will give that a try in the morning. Any other suggestions?
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Foxnut, the last one I tangled with my Son and I both had to pry with bars, pipes, hammers and about anything else I could get my hands on. When it finally moved it came off easy but it was hard to get started. It seemed to help after spraying with lube to have one person pull back on the shaft while the other used the pry bar and hammer. Just be carefull what you pry on so nothing gets damaged including yourself.
foxnut
B7100 HST
Dec 28, 2012
11
Thanks for the help and suggestions. I saturated the collar and PTO shaft with Liquid Wrench and let is soak and then if finally loosened up enough to slide the collar back and un hook it. Will make sure I grease/lube up before hooking the mower back up!
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
Glad you got it. Had the same problem with a used bx I bought. I don't think the mmm had ever been off. I satureated the joint with liquid wrench and used it and saturated it again. Still had to tap it off but while I had it off, i poured stp into the coupler before I put it back on. haven't had any trouble getting it off again.
foxnut
B7100 HST
Dec 28, 2012
11
Thanks - I have soaked it and I will be sure to grease both the PTO shaft and the coupler before I hook it back up. I am guessing that it has been a while since it was off the tractor and just needed some good lubrication. :D
pmr49
9
Renton, WA
I'm a really big fan of Break-Free, which is sold as a gun cleaner/lubricant. It really penetrates and is quite pleasant to work with. After wiping, it leaves a nice thin coat of lubricant. Cheaper by the quart and it lasts a long time.
Sterno
Kubota B6100D, B7100HST, Ber-Vac S51 3PT Snowblower, Kubota A450
Dec 9, 2012
74
12
Summerland, British Columbia
I scammed this off a jeep website, an ATF / Acetone mix is what I use, it works great and is dirt cheap.
PB Blaster=ok. A 50/50 mix of acetone & ATF=Best Ever! Here's the cold, hard facts from the April/May 2007 edition of Machinist's Workshop. They did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better.
Penetrating oil . Average load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
yeagisyeag
B7100HST
Jan 23, 2013
Willowick, Ohio
New member here. When I first got my B7100, I had the same problem with the coupler. I eventually took it apart to find the balls that lock it onto the pto shaft had worn into the sleeve, making it hard to release. I ended up turning the sleeve inside the coupler to give the balls a fresh surface to ride against. It's been a couple years and I'm going by memory here, so hopefully I've described it well enough. If you remove the snap ring and take a look inside there I'm sure you'll see it.
Jim
