Mower deck shield raising and lowering
gk527
Kubota B2650
Apr 6, 2017
140
Central Kentucky
I have a B2650 with the 60 inch mid mount mower. I’m looking for a way to raise and lower the shield from the seat while mowing. Right now I’m using a bungee cord to hold it up. Anyone have done anything like this?
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
Best way to go is to take it right off and be done with it. Problem solved. I took mine off before I mowed the first blade of grass!!
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
337
101
Ottawa, ontario
All I do with my mowers is drill a small hole at the end for the bungee cord hook to fit in. Raise and lower as required. I keep the shield for that one chance that I might pick up a rock.
gk527
Kubota B2650
Apr 6, 2017
140
Central Kentucky
I thought about drilling a hole too. Where did you drill yours?
08quadram
bx2350d; Taylor Way 48" tiller; Farm King 50" snow blower
Apr 28, 2014
289
strawberry point, ia
Mine is held up with bungy chord and is adjusted to just lift the chute a couple of inches. Makes a huge difference in grass distribution. I can hook the chord over brake pedal to lift it 90 degrees to fit through narrow locations. Dont take it off. I took out a jeep window and glass patio door by rocks getting thrown with mine held @ 90 degrees.
Sent from my SM-G930R4 using Tapatalk
thebicman
Feb 2, 2017
337
101
Ottawa, ontario
Don't have a picture of it. Drill a hole in the outside edge about a 1/2" in and large enough for the hook of the bungee to fit easily.
