Moving ZD326 that won't start
rentthis
1,010
25
summerville,sc
You would likely be better off posting your problem so the guys here can help you get it to run. I have a zd323 and I don't know of a release option.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,189
168
Hardisty, Alberta
There isn't a release mechanism on any of Kubota's diesel zero turns.
Digger Dager
M59 TLB, B3200 w/front snow blower, 3 @ ZD326 62" rear discharge mowers
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
Yup. No way to make it freewheel :(
As previously recommended, dollies will work. I have several metal dollies that are made for vehicle tires - Harbor Freight has them.
I am somewhat knowledgeable in the zd326 fuel and starting systems if you are interested in fixing it yourself.
SidecarFlip
Banned
557
Doing a little research, I see Hydro-Gear makes some of the pumps for the gas powered Kubota ZTR's but not for the diesel's.
I know you can freewheel Hydro-Gear pumps, I have them on my CC 60" tank.
Kind of a bummer not to be able to freewheel the back wheels.
5,419
2,108
The diesels don't have free-wheel release levers. Kubota makes the HST's for the ZD series mowers. They might outsource some of the parts for 'em but they ARE Kubota HST's. To move one, you push (or pull)-slowly. The harder you push or pull, the harder it works against you. Just go slow. It'll be fine. You'll hear a clicking noise which is normal.
mikester
M59 TLB
Oct 21, 2017
3,818
2,438
www.divergentstuff.ca
A lot depends on your trailer.
You can...
1.Use your come-a-long and take it for a drag onto your trailer.
2.use bogies/wheel jack for less dragging action on the wheels.
3.use your tractor/forklift to pick up the ZD and put it on the trailer. No dragging needed.
I prefer option 3
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
You can...
I prefer option 3
I have always thought about what I would do if one of my ZD'S broke down in the neighborhood. The mowers are too heavy to lift with my L4060, but I think I could get the rear a few inches off the ground and push it on the front wheels to home. I'll give it a test run soon.
