Hey guys, I am trying to figure out if it is worth buying the mulching kit for my mower. I know it's better for the grass to mulch it. Mowing now means I have plenty of grass cleanup when I'm done. I have a BX2370 and I don't have the bagger. I am trying to avoid it. I live in MA and my dealer said he does not feel is worth it. He said it struggles in wet grass or of it is to long. I am hoping someone with experience can shed some light on this.
Sent from my SM-G920V using Tapatalk
Well - there is a simple thought here........
IF grass gets too tall - you are screwed either way......even with a mulching kit, going to leave something behind!!!
Without the kit - blowing grass is not a problem - until you get to a place that cannot be blown onto! Wet grass aint gonna blow either!
If you have to clean up AFTER cutting now - the grass is either too tall or you are cutting too much off!
As for cutting wet/ damp grass - avoid that at all costS! Bad for getting grass out and bad on grass being cut no matter what you are using!
IF you can stay on top of your cutting - and the blades and kit are hooked up like they should - I think you will find it well worth it - OK - dumb question, WHAT DOES the kit cost?????
IF the blocking plate can come off quickly, I would consider getting the kit!
