MMM blade bolt torque
countrynerd
BX25D, L3301
Jun 6, 2016
119
thumb, MI, USA
Have 60 inch MMM on BX and specs says from memory 80 -90 or plus sum for blade bolt torque.
The question is do not have impact gun torque adapter I just tightened until it stopped moving with impact gun.
With air compressor of 3 CFM and gun rating of 480 lb at 5.5 CFM assume from farmer gut feeling is doing around 100 to 150 lb.
Should I be concerned over tighten?
5,561
Just remember you have to take them off some time! I dont use an air gun just a 1/2 socket and i go with a grunt and a half never had one come loose yet. but then I havent broken a bolt yet either
countrynerd
BX25D, L3301
Jun 6, 2016
119
thumb, MI, USA
Torque gun reverse strength is usually greater then forward for that reason. :)
I suppose worst case I strip and buy new part.
Be nice if the had pin lock in case slips off...
CountryBumkin
BX2370 w/LA243, Bucket, Grapple, QA Pallet Forks, 60" MMM, rear blade & rake
Sep 27, 2015
568
Central FL
Yes. The tightness of the bolt determines how much pressure is applied to the bevel washer which determines the "slip" allowed if the blade hits something. Too tight and the blade can't slip if it hits an unmovable object.
TripleR
Sep 16, 2011
1,911
SE Missouri
Yep, I hit a boat anchor several years ago and luckily I had mine torqued properly, I never tighten with an impact wrench, always use a manual torque wrench. I loosen with one though.
If needed, you can buy torque sticks.
3,058
I agree - a grunt and a half......now some grunts are better than others!:D:)
Toyboy
BX2230D - RCK60-22BX - BX5450
May 18, 2010
710
1,066
Hayward Wi
I don't think the blade will slip as easily as the belt driven pulley. I torque mine 80 ft lb. I don't trust doing it with an impact gun or a grunt and a half.
countrynerd
BX25D, L3301
Jun 6, 2016
119
thumb, MI, USA
The pancake air compressor with external 10 gallon tank only got it to 60 lb. so I ended up having to tighten to which I went to the max range of 86lb.
Took a few grunts I must be getting weaker.
