MK Martin Select SEL54 Snowblower
BlindBuck
9
PA
Hello long time lurker and finally became a Kubota Subcompact Tractor owner in August (BX2380).
I am hoping someone can provide some feedback on a MK Martin Select SEL54 3 point snowblower. I found what I believe to be a great deal on a new one that a local dealer has had for two years ($1,500 out the door). Every other 3 point blower I've looked at costs around $2,700-$2,850 (SB48EC MK Martin, SB1051 Land Pride).
I literally only know what I've learned from this forum and being an owner for a few months. I am familiar with the pros and cons of a front mount blower and with the amount I use the loader for the little bit it snows where I live in PA a 3 point is for me. I'm however very green to say the least with quality implements.
Thank you in advance for your help.
Sent from my Pixel 4 XL using Tapatalk
Dexter
L4701
Aug 27, 2016
Bay City, WI
I have an MK Martin SEL 68 snowblower that I purchased lightly used a few years ago. I think It was built in 2012 and still looks and performs like new. It has been a good blower for me. It is built well and works great.
One concern that some may have about this series of blowers is the lack of a replaceable cutting edge. Some other brands offer one but mine does not have one. For me it is not an issue as my driveway is gravel and I keep the skid shoes set up to keep the cutting edge raised up to prevent throwing rocks. If you are looking to clear down to pavement, you may want a replaceable cutting edge. I don’t use it a lot, but it sure is nice to have for the big storms.
BlindBuck
9
PA
Thank you for the reply and good feedback. I did see it doesn't have a replaceable cutting edge. I think I could get something fabricated if I ever needed to. I do have a paved driveway and I'd like to get down to it but I also don't want to mark it all up, so maybe raising it a bit is the answer. My driveway is kind of tricky and steep. It's only 450' long but has a switch back with a 14 degree grade. I'm not sure what to expect from the tractor going up it in reverse unless I only blow it going down. All very new to me as we purchased the land a year and half ago and our home was finished this past August.
SidecarFlip
Banned
557
For that price, there would be no hesitation on my part, I'd snatch it up. I don't use mine (Lucknow) much but when I need it, I have it. Keep it inside out of the weather and keep it greaased and oiled and it will outlast your tractor. My Lucknow has outlasted 3 tractors so far.
Dennis.D
L6060, Erskine hydraulic snow blower, back hoe
Feb 16, 2018
146
59
Central, ME,USA
i had a MK Martin, Meteor It was cheap $ but work fine for many years. Sold it after 5 or 6 years and still worked fine. Like Flip says keep it inside (if possible) and lubed not much to go wrong.
200mph
Mar 3, 2017
1,228
61
PA
With respect to 14% grade...
Suggest you invest in tire chains before attempting to clean the driveway. Sliding backwards downhill is no time to be thinking, "I wish I purchased those chains!"
