Mixing hydro fluids?
fruitcakesa
M 6040
Oct 26, 2010
873
301
Cavendish Vermont
The prior owner of the M4 071 used Napa premium hydro fluid for all the hydraulic services during the 1800 hrs he owned it with no apparent problems. I have always used Kubota Sudt for service on my other tractors.
Can Sudt be mixed safely with other “compatible” fluids?
6,740
Yes.
11,300
Would the same be true for front axle?80/90 vs Sudt? Are they compatible?
The front differential and axle hold around 2 gallons so draining and filling isn't such a big deal, but the transmission case at 15 gallons or so is an expensive proposition. I'm not in need of changing the oil yet, but when I do, I'm going to look at options in addition to UDT2. My local dealer's pricing is on par with Messick's but without the shipping cost, so today it would probably cost around $425 to drain and replace the transmission oil in my M6060, plus filters of course, so maybe $550 all in. On the up side, I'm not doing this every year.
I'm making the reasonable assumption that the M4 is basically the same as the M6060/M7060 in terms of fluid capacities.
4,032
Same answer. Yes.
Gears are “splash” lubed, …not pressure-lubed.
(that should start an entirely new argument) :ROFLMAO:
