Milwaukee M18 circular saw gutless?
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,442
1,736
Kalamazoo, MI
Just picked up a 2732-20 to use on a construction project and so far have not been impressed with this tool. Full disclosure, I have been using this saw with a 3.0 battery which is the biggest I have at this time.
I have found that if there is even the slightest bind on the blade, it stalls out and when I check the battery, the charge indicator lights flash.
Milwaukee claims it has all the torque of a 15 amp corded saw but I disagree.
Nowhere in the saw owners manual is any wording about recommend battery size or any explanation of how they arrived at the rated specifications.
Anybody have thoughts or different experiences with this tool?
Hkb82
Nov 17, 2021
418
330
Ontario Canada
You’ll definitely get better performance with the larger 5 or 9ah batts but if you don’t already own them they can get pricey.
7,116
I have an M18 circular saw that came with a kit several years ago.
Think blade is 6 1/2"(?).
No issues for me, but I do use a 5.0 ah battery.
mcfarmall
Sep 11, 2013
1,442
1,736
Kalamazoo, MI
Mine is the 7-¼" brushless unit with magnesium shoe. Wish it was a blade left model like my corded drop foot Milwaukee.
OntheRidge
Nov 1, 2020
448
524
I have this same saw, the 1st one I had bound up and stopped working within a week or so, I returned it, the replacement works great with any of my batteries, although, obviously, larger ones last longer. Good luck!
58Ford
BX23s, LA340, BT603, RCR1248, PFL1242, STB1072
Jan 1, 2022
248
207
SW Washington
We typically avoid battery saws unless we have to be in the rafters. We did have a Mikita running and it took us a while to realize that we had to baby it more than our corded magnesium skillsaws. Dual batteries on it if I recall.
Jchonline
599
Red Feather Lakes, CO
The minimum I would use is the 5AH battery. 8 or 9 is better.
crmorse
'20 RTV-XG850, '16 L47 TLB, '06 JCB 506CHL, '99 JD 455G, 1953 Ford 8N
Nov 28, 2016
102
Anniston, AL
The battery size makes a huge difference. I can tell the difference between my 8Ah and 6Ah. With the 8Ah it has more torque than my corded Makita hypoid saw.
dclauria
Kubota L4060HSTC, L4479 snowblower, EA 60" grapple, LP GS2584, LP BB2572
Jan 1, 2022
40
46
Northern Michigan
Similar experience here... I'm an electrician and I have many Milwaukee tools and a variety of batteries
The 9ah or 12ah is the one I chose when I want to do some serious work.
BX23-S,57 A-C D-14,
5,900
just went to the website, the ONLY battery I can see(kinda) , is to use the HD12(750 cuts..), which I assume is a 12AH battery
NO where is the 'specs' do they say WHAT battery is needed, just M18 ,again I'll assume Millwakee, 18 volt ?
