So what do you think about instead of buying RimGuard (expensive) or washer fluid (a little expensive) buying distilled water at 80 cents a gallon and adding a cup per gallon of rubbing alcohol?
I have a transfer pump and most of what I would need to make the manifold to fill the tire. Also not afraid to do it. So the water would be (30 gallons per tire) 23 bux, the alcohol 15 to 20 $ per tire. 25 or or so dollars for parts , I feel I am way ahead here. Am I wrong?
Also it never gets much colder than 20 degrees F here.
