M9960 engine stops
bella
m9960
May 24, 2016
11
dexter mo
Baling hay 5 by 6 engine stops going uphill. Changed fuel filter and water separator still happens
9,690
A lot more info is needed, explain the problem further! ;)
bella
m9960
May 24, 2016
11
dexter mo
Tractor seems to run out of fuel engine stops. Happens randomly no warning usually uphill. Changed filter and water separator .
7,151
I had a similar situation. What it turned out to be was a glob of grass at the bottom of the fuel tank that was pretty much plugging the outlet hose.
This was on a Deutz. I removed the fuel line and fished out the bottom of the tank. Let a little fuel run. Reinstalled line (had already installed new filter) and it ran fine.
