If you have all the vents located in the inside headliner. then the works are up top. If you have vents next to the instrument cluster, then the 'works' are under the seat. If overhead, there are (I believe because I haven't pulled them lately) 6 longer screws that hold the top to the top of the ROPS structure.
Best way to determine which screws are which is start backing them out. The longer ones will be the top hold down screws, the shorter ones retain the headliner. As you back them out, run back in the shorter ones and leave out the longer ones and the top will come off.
You can mark the longer screw heads with paint if you want for 'next time' to make it easier.
