Have a M8540 that started loosing power and running rough when under a load. Drained the water separator and cleaned it and changed the fuel filter. Bled the system still doing the same thing. Can watch fuel level fluctuate in the separator glass. Talked to dealer and suggested drain the tank. Did that still having same problem. If we let tractor sit overnight separator bowl fills back up with fuel and tractor cranks right up and runs good for about 5 minutes and then same problem reoccurs. Manual mentions checking tightness of the fuel coupler bolt but does not say or show where it is. Checked with dealer and they don’t know where it is. Any help with where bolt is or experience with this problem would be greatly appreciated.
