M8200 will not turn over
rgbeaver57
M8200
Feb 6, 2017
Canton, Texas
I have a M8200 that will not turn over when you turn the key. It just clicks under the instrument panel. I have tested the battery and it's fully charged. Also, have tried to jump the tractor with no luck.
Any ideals on where to start at trouble shooting the problem?
Thanks
rentthis
1,010
25
summerville,sc
Will it turn over if you jump between the positive starter wire (battery cable) and the small solenoid terminal?
2,749
Will try tonight when I get home. Is the small solenoid terminal on top of the starter?
Rentthis is pointing you in the right place - this will determine IF starter/solenoid is good or not, and then you can backtrack from there.
I would suggest turning the key and moving the pto lever a bit or the hst lever (if it has) and anything else that has a safety device.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,223
144
Coyote Flats,Texas
Welcome to OTT
Be sure tractor trans is in neutral before shorting across starter solenoid!!!!!!!!!
Check all 4 battery cable connections to be sure they're clean & tight.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,223
144
Coyote Flats,Texas
Jim, thanks for the safety input. I should have my butt kicked for overlooking something so obvious.
Mike
Mike
You're very welcome. Many people have been killed or disabled from jumping across tractor starter solenoid. One can never be too cautious!!!!!!!!
Jim
