M7040 Compressor Failure?
TxFireman
M7040
Aug 3, 2026
I picked up a 2013 M7040 with 1400 hours from a family member. They stated “AC doesn’t blow cold”. After checking a few things I’m assuming compressor is shot!
I have already:
  • Cleaned cabin filters
  • Inspected evaporator under seat (all clear)
  • Cleaned condenser and radiator
  • Installed shutoff valves in heater core lines
  • Put gauges on with tractor running and AC on it shows 100 on both low pressure side and high pressure side
  • Clutch is spinning continuously
Just looking for ideas, suggestions or confirmation before I tear into it. Also curious if anyone can recommend the best place to buy after market components. Thanks in advance!
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,039
979
Amsterdam, NY
Never had to buy one but doing a quick search I found prices all over the place - $350 from tractorpartsasap to almost $1,000 from Kubota.
Maybe another member with more experience will chime in soon.
number two
B3030HSDC L2501HST
Mar 26, 2021
422
200
Northern Lower Michigan
Is the compressor clutch engaged.or is the clutch just turning without turning the compressor shaft itself?
In the Texas heat,those gauge readings look like you're out of refrigerant?
No juice will show about ambient on the gauge.
Good Luck!
BAP
Dec 31, 2012
3,176
1,293
AP Air Inc is a good source for tractor air conditioning parts.
Fedup
367
144
Winchester
Good Luck!
I guess I must be stupid, but could you explain a bit more about what his pressure readings indicate? How exactly does ambient show up on pressure gauges?
TxFireman
M7040
Aug 3, 2026
Good Luck!
I'm not sure if the video worked or not, but it appears the clutch is engaged and the shaft on the compressor is turning
TxFireman
M7040
Aug 3, 2026
Low Pressure cut out kicked in , low on refrigerant . Pull a Vacuum on system & checked for leaks 1st.
but if the low pressure cutout kicked in the clutch wouldnt be engaged would it? it seems to be engaged in the video, shaft spinning.
number two
B3030HSDC L2501HST
Mar 26, 2021
422
200
I am the stupid dude!
It's been my experience that when the AC system is at rest or empty,the gauges will show approx ambient temperature.
The OP may very will have a bad compressor.
number two
B3030HSDC L2501HST
Mar 26, 2021
422
200
I'm thinking your compressor may very well be toast.
Seen it occasionally,as bee-positive posted!
I usually look up the Kubota part number and do an internet search for affordable replacements.
Good Luck!
Fedup
367
144
Winchester
In my experience pressure gauges don't read temperature. Ambient or otherwise. His gauges looked (to me anyway) to both read approximately 84 PSI. My experience tells me that's NOT low on charge. 70 to 80 PSI static pressure would about right in any system this time of year. He has problems, granted, but the system being low on charge is not one of them. If we're going to offer help, let's at least offer correct information.
Bee-Positive
Nov 16, 2022
1,039
979
Amsterdam, NY
I'm an Energy Engineer retired after 30+ years working for NYS, Johnson Controls, Siemens, and Trane in the HVAC-R field doing retrofit energy projects. MHO - if it were me I'd replace the compressor.
TxFireman
M7040
Aug 3, 2026
I agree. Looking around now for compressor, drier, and expansion valve at least. Trying to device on weather or not to grab a condenser and evaporator. I’m a do it once kinda guy, but also trying to not spend a bunch of $$ on things I don’t need.
Bee-Positive
Nov 16, 2022
1,039
979
Amsterdam, NY
Hard to tell if the expansion valve is bad or not unless the system is running and you can determine the symptoms. But a bad valve can ruin your day by damaging other components so adding the drier and expansion valve, given their age, might be worth it.
If the condenser coil and evaporator coil look to be in good shape I wouldn't think you'd have to replace them. I imagine if a lot of moisture got into the system they could corrode from the inside out eventually, but I'd roll the dice on that one.
Do what your budget allows.
Fedup
367
144
Winchester
A/C projects are not always a "do it once" type of thing, even for those with experience at it. You (apparently) have a compressor problem, probably more, and don't yet know the extent of it all. MAYBE all you have is a clutch or electrical problem. You stated earlier that the clutch is spinning continuously. The pulley spins continuously. The clutch spins when it's engaged if it's working properly. In this case nothing is certain yet. If the clutch IS working and your pressure gauges read what's in the photo above when running then yes, "the compressor is shot", You will need a compressor, a drier, an expansion valve, a bunch of O rings, a system flush kit, and a vacuum pump. That will get you started. If all that works out and there are no electrical issues to deal with as well, you could be good to go.
There was another A/C thread on here recently concerning electrical issues on a different model that indicated a nightmare of an electrical system. Hopefully yours is not like that one.
TxFireman
M7040
Aug 3, 2026
Ok thanks. The clutch is definitely engaged, as seen in the video (not just the pulley). If I turn the AC switch off, the clutch disengages. I have a vacuum pump, gauges, etc. I’ll probably go ahead and do compressor, drier, expansion valve and a flush. I really don’t want to do condenser and evaporator if I don’t have to.
