M6060 rear remote
10,397
1970cs
1,124
Grand Ledge
Again, here where accuracy with the exact tractor style helps me out. Open station or closed?
#1 is standard.
#2 your choice self cancelling or detent
#3 same as above
Open station #2 valve is M7604 S.C.
M7605 detent
Open station #2 lever kit M7607
Closed station #2 valve is M7610 S.C.
M7611 detent
Closed station lever kit M7687
Pat
Jdhager
Owasso ok
Thanks. Got another question tho gonna hook up a snow plow the plow has two hydraulic cylinders is it better to git another rear remote or can u unhook the bucket curl hoses and use them for the plow angle? Has anyone been there and dun that yet?
1970cs
1,124
Grand Ledge
Yes, you can add hoses and couplers to match the curl circuit.
Also use the closed station numbers for your remotes.
Pat
10,397
You would be better off adding a third function controller to the loader! ;)
