I have changed the hydraulic fluid in my M4700 tractor before with no problems but this time I let it sit draining for three hours. The reason I drained was that this past winter my hydraulics would not work when the ambient temps were below zero. After filling with oil I have no steering or hydraulics. I have run the tractor three or four times for approx 30 minutes total run time with no luck. In fact at the start the steering wheel was basically locked because of no pressure now it turns freely but won't try to move the wheels. I have loosened a pressure line on the hydraulics pump and have no fluid there. I am sure that the pumps have just bled down but how do I prime them? Was there a sump screen that I should have cleaned before I dumped 40 some qts of oil in?
