Hey Guys, just a quick question about the oil level in the front axle. I have a slow leak in the left side wheel assembly and want to make sure not to run the axle low on gear oil. My problem is there is no plug or dip stick to check the oil level, the dealer says to drain it and put in the amount the manual says is capacity. Is there any other way to make sure there is the correct amount in the axle. if I put in too much it leaks out the propeller shaft housing. I would appreciate any thoughts.
