M135GX Shuttle Shift Problem
isucowboyvet
L3800HST
Aug 28, 2013
Richland, IA
My new to me 2013 M135GX with about 2100 hours has been on my place for about 2 weeks and has been working flawlessly, until tonight. I started the tractor and let it warm up for about 10 minutes and went to feed cattle. Disengaged the park brake, shifted to medium range and flipped the shuttle to forward. Nothing. Indicator on the dash still read neutral. Flipped it to reverse and engaged properly back to forward and it worked. Now about half the time I shift to forward it take 3-5 attempts to get it to go forward. No noise, no grinding, just does nothing. Sometimes it works normally sometimes not. Anybody else have this problem? I'm hoping it's just the switch. I just paid a lot of money for this tractor and I pray it's not a transmission problem.
Sent from my SM-G955U using Tapatalk
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,274
177
Coyote Flats,Texas
I'm not familiar with a M135GX. I will advise you to acquire a WSM for your tractor.
I'm glad my Kubota M7040 & other tractors I own have manually controlled hyd valves to operate trans not electronically controlled as I'm guessing your tractor is.
Fedup
337
130
Winchester
Not exactly one of the "knowledgeable members" on this site, but my experience with computer controlled transmissions has shown that your symptom (if NOT accompanied by an error code) is usually the shuttle switch itself or the related wiring. It often gets more use than most other switches in the cab.
isucowboyvet
L3800HST
Aug 28, 2013
Richland, IA
Update if anyone is interested it was just the switch. $170 later and taking the column apart it is working as it should. Have a good day everyone!
3,682
Those little Compact tractors have a lot of safety switches these days...:D
That’s a heck of a FEL on that thing! Gud luuking matchene!
9,607
Yes thank you for the solution reply!
Your very likely to help someone else down the line.
