M108 convenience outlet
Snaefell Rancher
M108s, SSV-65
Jul 2, 2026
BC
Hello, I've got a 2016 M108s with a cab. The tractor came equipped with a 12v convenience outlet, mounted on the floor behind the seat. I have been running my JD bale monitor off it by attaching loose wires with crimp connectors to the existing terminals. Mickey Mouse I know, been doing it this halfarsed way for years. This hay season saw more problems with this poor set up, I want to do it right for next years' peace of mind. Have been trying off and on to find the pigtail to connect the JD monitor wiring to the outlet. The local Kubota dealer says the plug is not available from the mothership. I hear that Agco sells one that fits,,, not sure about that.
Does anyone know where to buy a pigtail that fits the Kubota outlet?
Jim L.
883
180
If you would post a picture of the 12v convenience outlet, it would narrow down the vendors.
BAP
Dec 31, 2012
3,172
1,291
Check with JD. Used to be that you could buy extension harness for things like baler and chopper control boxes to lengthen the power cord on the boxes and match up with the outlet in the tractor. Would probably be in the parts book for the baler. I bought several of them to fit the box on our baler and pull behind choppers many moons ago.
JasonW
806
558
Al
Do you use the convenience port(12v outlet) for anything else besides the baler? Or the baler on a different tractor?
You could convert both ends to a SAE style plug on the cheap end or a Deutsch connection on the high end.
My vote would be have it wired to run the baler with deutsch connectors and still have a 12v outlet or USB style charger(phone charger, radio) off the same circuit. Depending on the amp load for the baler controller.
Snaefell Rancher
M108s, SSV-65
Jul 2, 2026
BC
Jim L ; going to try
BAP; found some info online that said the JD plugs are not compatible but I might ask the dealer
JasonW ; I only use it for the baler, so far, but i like your ideas
Snaefell Rancher
M108s, SSV-65
Jul 2, 2026
BC
Well I and the wife found a pigtail that fits, on Amazon, $32.46 including taxes.
I waited to verify it fit before reporting back. Seems to fit, have to do the wiring to complete it.
I did verify with a JD tech that they do stock them and they will fit the Kubota, but those are 70-80 dollars.
So here we are, after 11 seasons, I might have a wiring solution that won't come loose at inopportune moments.
P.S. I tried and failed to post a picture of the outlet in this forum.
Thank you all who offered assistance.
BAP
Dec 31, 2012
3,172
1,291
Great to hear that you found a solution
