Lug Nuts
4,477
Anybody know what size the lug nuts are for a GM 1/2 ton 4wd pickup,, I have to find out everything I have is to big or to small ,,,,,,and that lug wrench supplyed with the truck SUCKS
Stumpy
L175
Dec 1, 2011
848
NE Ohio
They should be either 3/4", 13/16" or maybe 7/8" if it's got the heavy duty axles. 3/4" crosses to 19mm if you're using metric sockets. Those were the most common truck lugs I saw at the shop.
4,477
Ok I found out they are 22mm or 3/4 or 7/8 oe 13/16,, seems they used different nits on different wheels,,, thays from the local chevy dealer
4,477
Ok I found out they are 22mm or 3/4 or 7/8 or 13/16,, seems they used different nuts on different wheels,,, thats from the local chevy dealer
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Guess I forgot but I just checked and 22mm crosses to 7/8ths. You oughta be able to eyeball it with a tape measure now that you've got a range of choices.
4,477
Ya know I should fiind a cross ref from metric to sae some place and keep it with the rest of my junk
