Lube on wheel stud/bolt threads.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
I personally use a a small amount of coppercoat anti seize on wheel studs/bolts when installing wheels. I have never had a damaged wheel from one coming loose but have lost studs, nuts, bolts from seized threads that were put on dry. I also check my torque after installing wheels.
3,314
Do you adjust the torque setting you use to compensate for the increased pull the nut will exert on the stud, due to the lubrication effect of the anti seize?
WAS BANNED FOR NSFW PICS
5,161
Lug nuts are the exception to the rule of using a non seize product to assist in future disassembly. The torque value is for dry threads. The most that I would ever do is to put some grease on the exposed threads once the wheel was mounted to prevent the studs from rusting. I honestly can't ever remember seeing wheel studs rust.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
Nope, just the manufactures torque spec with a tiny bit of lube.
Pawnee
L2501
Jul 1, 2021
371
336
Ontario Canada
If you lube and torque with the dry specification you are over torquing the fastener.
A tiny bit doesn't mean anything.
3,314
But there must be some factor that accounts for lubrication, and would result in the same pull on the stud, with less torque applied to the nut right?
Is such a factor not common knowledge for those with mechanical knowledge?
Seems like it should be available if one is smart enough to find it, which I am not...
6,183
Consult the manufacturers data sheet - they usually speak to this issue. The K factor for antisieze is typically .10/.13. Compare that to .15 for oiled threads and .20 for dry. That translates into reducing torque values to around 80% to 85% of dry when using antisieze products.
3,314
That seems reasonable and common sense really...especially since torgue required is specified in a range anyway. Thanks...
Lube them up, torque to 80% of max dry value and feel good about it I guess.
6,183
Its common sense if you understand what you are doing when you torque a fastener. Shigley's Mechanical Engineering Design devotes a chapter to the physics and mathematics of fastener torque.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Been doing that on all my vehicles and all of my customers vehicles for a half century without one single loose, stripped, galled, or seized stud or nut. Don’t get me started on what I’ve received from other shops… Butchers :rolleyes:.
P.S. Don’t forget the brush hog blade bolts;).
torch
Jun 10, 2016
2,828
1,077
Muskoka, Ont.
I live where they salt roads and have seen wheel studs rust. I use anti-seize but derate the torque by 5%.
5,185
Yup.......rust from road salt, and from near the ocean too!
whitetiger
Nov 20, 2011
3,341
1,761
Kansas City, KS
Rusted wheel bolts and nuts are very common. Landscape companies that do chemical applications, ice melt salt, fertilizer plants, wastewater treatment facilities, chemical production plants, feedlots, the list goes on and on.
Nicksacco
Kubota L35 TLB, 2014 RTV-1140CPX
Sep 15, 2021
758
496
Bahama, NC
This is an interesting topic indeed.
I've always added anti-seize to bolts - especially lug bolts.
Certainly those who've done engine work know about certain engines requiring lube on the head bolts.
I found a few things I thought would interest ya'll and maybe provide some discussion.
Smartbolts: Anyone ever heard of these?
This is fact-filled-fun paper from NASA on the subject (download it).
I'm no rocket scientist, but for those of you that are, wouldn't different thread types affect this kind of thing too?
Take NPT and NPTF fittings for example and the way that the threads mate to form a seal. I have gotten properly confused lately reading about hydraulic lines and fittings JIC, pipe, etc. as I rebuild my tractor. Fascinating, but as we know - sometimes you have to separate fact from opinion.
Bolts (threads) to hold things together and pipe threads (to both hold together and seal out fluids) must have some common relationship with torque and tension and lubrication.
Another article takes into consideration different types of lubrication.
Man, a guy could get lost in all of this eh?
Is there a rule of thumb or something? There's a video in this one demonstrating "real world" lubrication I thought was likely true.
Pawnee
L2501
Jul 1, 2021
371
336
Ontario Canada
Thanks for that Nicksacco.
I really like the smart bolts!
I am going to try to read the NASA report.
Later
6,183
Take NPT and NPTF fittings for example and the way that the threads mate to form a seal. I have gotten properly confused lately reading about hydraulic lines and fittings JIC, pipe, etc. as I rebuild my tractor. Fascinating, but as wep] know - sometimes you have to separate fact from opinion.
The proper way to assemble tapered pipe threads is by counting turns. Your goal is to establish a seal not a fastener tension.
Variations in friction make using tightening torque is as an indirect measurement of clamping tension an imprecise process. There are more accurate methods, most notably measuring fastener stretch, but they are more complicated and require time consuming setups and expensive instruments. Torque to yield and tension indicating fasteners are another alternative but they are similarly expensive. So measuring tightening torque remains the most commonly used method of preloading threaded fasteners.
In most common applications the desired fastener preload is 80% of fastener proof strength. This allows for variations in actual material strength and measurement inaccuracies.
The actual torque calculations include a term called the "K" factor which approximates the loss of tension attributable to sliding coefficient of friction in the assembly. Lubricating or plating threads changes the coefficient of friction significantly and consequently the value of the K factor used to calculate the torque needed to produce the desired tension.
T = (K D P)/12
  • T = Torque (ft-lbs)
  • D = Nominal Diameter (inches)
  • P = Desired Clamp Load Tension (lbs)
  • K = Torque Coefficient (dimensionless)
If you want a simple rule of thumb its easy - look it up in a table. If the torque value you have been given is for dry threads you must reduce it if the threads are plated or lubricated. There are commonly accepted vales for the K factor to use. Published K factors are determined by experimental testing - e.g. repeated measurements of torque and the resulting tension are made and the K factor is calculated from those results.
If you don't reduce torque you risk stretching the fastener past the point of plasticity which will permanently deform it or even break it. Deforming the fastener results in a loss of clamping force and a weakened fastener.
Thats all engineering fact - not opinion or myth. As I said in my previous post if you want to see the engineering mathematics of it truck on down to your local library and check out a copy of Shigley's.
3,747
Typical gov’t exercise of “measure it with a micrometer, mark it with a grease pencil, cut it with a hatchet”.
All that documentation and detail, …time, money, man-power and resources …running a technical experiment…. which results in completely USELESS data…because they FAILED to even specify the lubricant used. :rolleyes:
Mr.Bentwrench
Kubota B3030 WD45 Ford9N
Apr 20, 2022
Southern IL
So, are you putting the neversieze on the threads, or on the taper where the nut seats in the rim, or in the case of lo-boy rims, on the flat that meets the clamp? I just put some new clamps on a low-boy installation, and the difference in number of turns between old unplated and new plated clamps was astounding.
