I have a Kubota L2550 gst older tractor, have lost the top 4 gears, replaced the filters and hydraulic oil. Pulls good in bottom gears, power steering works good. any one have any ideas where to go now?
Hey Mountaindan, sorry to jump in here but just looking for a bit of advice. My l2550 GST has similar problems to yours, no power in speed 5 - 8 and even lower gears dont seem to be right. Any hills or obstruction and its struggling. I pressure tested all the valves / gear selection ports etc and pressure is around 25 bar which is good I believe. The main mechanical clutch is fine so Im thinking its the multidisc clutch pack inside the trans. Was that the problem with yours or. Not many of these in Ireland and very hard to get advice on them. Any help greatly appreciated. Thanks,Got a chance today to do a little better troubleshooting, if I put a load on the tractor it would stop in all gears. My clutch petal had no play, adjusted it tractor moves in all gears now till you put a load on it.. I will be pulling it apart when the weather warms up. Anything I should look for while I am in there except the clutch, pressure plate, throw out bearing, and a pilot bearing? Thanks again for all the help
How did you determine the main mechanical clutch is good?Hey Mountaindan, sorry to jump in here but just looking for a bit of advice. My l2550 GST has similar problems to yours, no power in speed 5 - 8 and even lower gears dont seem to be right. Any hills or obstruction and its struggling. I pressure tested all the valves / gear selection ports etc and pressure is around 25 bar which is good I believe. The main mechanical clutch is fine so Im thinking its the multidisc clutch pack inside the trans. Was that the problem with yours or. Not many of these in Ireland and very hard to get advice on them. Any help greatly appreciated. Thanks,
Eire Lad
Main diaphragm spring clutch was replaced not long agoHow did you determine the main mechanical clutch is good?
That still doesn't mean it's not bad.Main diaphragm spring clutch was replaced not long ago
