Looking For - Upper 3pt Lifting Rod Pins - B7200HST
ttj49
B6100-DT
I'm looking for the upper lifting rod pins for a B7200HST. The rod holes on the lift arms are 1/2 inch on both R and L rods to accept a 1/2 inch threaded end, but the right pin hole on the right rod is 3/4 inch and the left pin hole on the left rod is 5/8 inch. I actually only need the left pin - 1/2" threaded end / 5/8 inch pin end. I can't find anything on line with a 1/2 inch threaded end. Don't want to pay Kubota 40 bucks for one pin. Any suggestions would be appreciated. Thanks.
5,150
OK you need to find a better parts supplier!;)
Your turnbuckle your price $114 my price $24.72
Three point top link side pin you price, $40 my price $13.49
and yes these are Genuine Kubota parts!
Try going to: http://www.goldeneagledirect.com/index.php
If you don't have the parts manual, I think it's also on kubotabooks.com
if not go to Kubota.com, parts (on top), illustrated parts (on the side) then put in your Model # and get the parts diagrams and part #'s.
ttj49
B6100-DT
Hey, thanks for the link. I'll check it out. I discovered today the left lift rod is supposed to have the same 3/4 inch diameter hole as the right rod. A previous owner, for some strange reason inserted a bushing into the ball swivel hole to reduce it to 5/8. I couldn't tell due to wear, but darned if there wasn't a bushing in there, so problem solved, removed the bushing and actually found the pins here at this site for 6.95 each, plus 8 bucks shipping. Now lets see if they hold up.
http://www.stevenstractor.com/acces...ift-arms-related-parts/pins-bushings.html?p=1
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
