Loader mount bolts breaking off
LDPosse
B7100 HST
Jul 2, 2014
Tower City, PA
I have a ‘91 B7100HST that I installed a woods LS72 loader on about 5 years ago. I have been having issues with the front most bolts snapping off where the loader frame bolts to the tractor frame. I most recently upgraded the bolts from class 8.8 to class 10.9. So far this is holding. I wanted to see if anyone else has had similar issues, and what fixes they have done.
fishdrivel
b2501
Nov 24, 2020
15
georgia
I was breaking bolts on a tractor I once owned.
My problem was caused by ramming hidden tree stumps.
Some of these I rammed by accident!
3,091
CAn you post Pics of the broken bolts? 8.8 bolts are hard and will shatter where grade 5 bolts are resilient and will survive. grade 10 bolts, are likely harder than the tractor and may open-up the tractor mounting holes.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,143
940
Williamstown Ontario Canada
Photos of the broken bolt faces might tell a lot.
i.e. are they failing from fatigue or being failed by an overload such as being sheared off.
Typical loader frame designs have the rear axle dealing with a substantial part of the load. The front axle just holding stuff up.
Any relative movement in the loader frame between the front axle area and the rear axle will create major loads at the front mount(s).
Dave
SidecarFlip
Banned
548
Did you torque them correctly or just 'good and tight'?
4,440
Does your loader setup have any steel support going from the pod the loader towers set in or attached to and going back to the rear axle? If you don't you're putting a lot of stress where your bolts are giving up!
