Loader Hydraulic Cylinder Replacement
virvis
l4200
Oct 12, 2015
marysville
Kubota l4100 with a LA680 loader. Cylinder Part # 75556-63110 . Tried to have it rebuilt but there's an issue with the rod. Messicks price is just under $800. Anyone have any suggestions...aftermarket....used. Hate to drop $800 on 1 cylinder.
7,669
Find another rebuild shop! A good shop can make a new rod at a reasonable cost, I'd think.
What is the issue with the rod? I've had rods with a bend in them straightened and used for years. Had rods with small bits of rust in surface polished and still using after many years.
Get a bid on fixing what you have and compare it to new.
virvis
l4200
Oct 12, 2015
marysville
The quote to repair the current one is $500-600. vs new one around $800. Sounds like the rod is rusted.
PaulL
B2601, MX5200.
Jul 17, 2017
2,798
1,791
NZ
If the rod is rusted, can you recondition it yourself? Steel wool and a bit of time may be all you need. That may be expensive in a shop because their time is expensive, where your time may be mostly free.
7,669
Something that will take rust off of chrome is aluminum foil waded up in a ball tightly and simply rubbed on the rusted area!
retired farmer
tractor, loader, cutter, blade
May 25, 2020
188
108
sheridan
This does work, also dribble some coke cola while rubbing. Vinegar may do also as it's an acid.
rr
